divide helper
Use {{divide}} to calculate the quotient of two numeric values—either from your record fields or from hard-coded values.
Usage
{{divide number1 number2}}
  • number1: A numeric field or string literal representing the dividend.
  • number2: A numeric field or string literal representing the divisor.
Examples
  1. Dividing two record fields
    {{divide record.item1 record.item2}}
    If record.item1 is "33" and record.item2 is "11", this returns 3.
  2. Using hard-coded numbers
    {{divide "2002" "100"}}
    Outputs 20.02.
  3. Combining a record field with a hard-coded value
    {{divide record.total 3}}
    If record.total is 33, this yields 11.
  • The result is a floating-point value when division is not even (e.g., 10 / 3 = 3.3333).
  • Dividing by zero (or a zero-like value) can cause errors or unexpected behavior.
  • Confirm your inputs are numeric or can be parsed as numeric.
