add helper
Use {{add}} to sum any number of numeric values—integers, floats, or decimals. You can pass in numeric fields from the record or hard-coded values.
Usage
{{add number1 number2 ...}}
  • number1, number2, ...: Any valid numeric inputs (fields or literals).
Examples
  1. Summing order item quantities
    {{add record.items.[0].quantity record.items.[1].quantity}}
    If the first item has a quantity of 2 and the second item has a quantity of 1, it returns 3.
  2. Adding hard-coded numbers
    {{add "2" "5"}}
    Returns 7.
  3. Combining multiple fields
    {{add record.tax record.shipping record.discount}}
    If record.tax is 5.25, record.shipping is 10, and record.discount is -2, this returns 13.25.
  • You can pass as many arguments as needed.
  • Ensure each argument is numeric (or can be parsed as numeric); otherwise, the helper may produce unexpected results.
  • Negative values are handled naturally, allowing you to sum discounts or other adjustments.
