ceil helper
Use {{ceil}} to round a numeric value up to the nearest whole integer (i.e., always rounding to the next higher integer if decimals are present).
Usage
{{ceil field}}
  • field: A numeric or string-parsable numeric value (e.g., 45.75, "45.75", or record.subTotal).
Examples
  1. Rounding a record field
    {{ceil record.total}}
    If record.total is 45.75, this outputs 46.
  2. Handling decimal shipping cost
    {{ceil record.shipping}}
    If record.shipping is 62.02, the result is 63.
  3. Hard-coded numeric strings
    {{ceil "45.02"}}
    Returns 46.
  • Negative values are rounded “up” toward zero. For example, {{ceil -2.8}} yields -2.
  • If the value is already an integer (e.g., 45), the helper simply returns it unchanged.
  • Ensure the field can be interpreted as numeric; otherwise, results may be invalid.
