FAQ: Trigger integration flow using Mass Update
You can sync multiple records from NetSuite to Salesforce using mass update which avoids the tedious manual task and gets the records transferred quickly and error free. To do so, you need to configure the NetSuite real time export record.
Configure NetSuite real time export record
  1. Go to Flows, select the NetSuite to Salesforce flow.
  2. Click on NetSuite Listener to edit the settings.
  3. Configure Execution context by adding User Event and Execution type by adding Edit.
  4. Click Save.
