Following are the scheduled CAM scripts in NetSuite and their summary for your reference:
- Celigo Batch File Poller: Celigo internal script to fetch files from FTP for integration build using the legacy integration (not integrator.io).
- Celigo Integration Log Manager: Celigo core script that keeps the integration logs up-to date.
- Celigo Licensing Audit: Celigo core script to ensure the licensing of the installed products is up-to date.
- Celigo Batch DataFlow Scheduler: Celigo core script that schedules the batch flow build on the legacy framework V2 (not integrator.io).
- Celigo Integrator Batch Manager: Celigo core script that processes the batch flow build on the legacy framework V1 (not integrator.io).
- Celigo Version1 to Version2 Migrator: Celigo internal script used for old migration for V1 to V2 legacy framework.
- Celigo Integration Job Status Checker: Celigo core script to ensure that a job get doesn't stuck due to any unexpected error by NetSuite or by Celigo.
- Celigo TF Scheduled Test Trace Remover: Celigo internal script used to run test cases on the solution and clean up any records created. This script will not process any data on a customer account, and is used only for internal test accounts and our our partners build solutions and test cases.
- Celigo TF Scheduler: Celigo internal script used to run test cases on the solution and queue test cases on for the runner. This script will not process any data on a customer account, and is used only for internal test accounts and our our partners build solutions and test cases.
- Celigo TF Scheduled Test Runner: Celigo internal script used to run test cases on the solution and process test cases on scheduled. This script will not process any data on a customer account, and is used only for internal test accounts and our our partners build solutions and test cases.
- Celigo TF Scheduled Test Dispatcher: Celigo internal script used to run test cases on the solution and process the test cases. This script will not process any data on a customer account, and is used only for internal test accounts and our our partners build solutions and test cases.
- Celigo Consumer Runner: Celigo core script to process data for RealTime export and send them to external system.
- Celigo Realtime Job Accumulator: Celigo core script to keep the process record count and status up-to date for RealTime export jobs.
- Celigo CashApp record list update: CashApp interval script to create metadata in files to help in CAM Dashboard to allow users to select drop-downs.
- Celigo CAM Clean up Script: CAM internal script that runs allows to create duplicate data (payments, invoices), incase any file/batch is processed multiple times.
