Create a data ingestion sync
Creating a Celigo sync involves three standard steps: configuring your source, setting up your destination, and scheduling the run. This article covers the entire wizard flow, from choosing a source connection and selecting objects or exports, through picking a destination connection, to setting a run schedule, so you can get a working sync end to end.
To learn more about data ingestion and Celigo sync, see Celigo sync overview.
Prerequisites:
All Celigo subscriptions include one active sync. Contact your account manager for details on Data Ingestion add-ons and volume packs.
What a sync contains
At a minimum, every sync includes the following:
  • Integration scope - Name and organize the sync within an integration that exclusively targets the same destination application.
  • Source application - Identify a single source application alongside its data (tables, records, objects, fields, and key characteristics).
  • Destination application - Select a single destination application with configured data ingestion settings (database, table, and schema).
  • Execution schedule - Set a run frequency (on demand or scheduled) using either a historical (initial) or periodic refresh data flow.
Create a sync
Configure your source data, select your target destination, name your schema, and set a run schedule.
  1. Go to Home home-icon.png, select Create, and then select Sync.
  2. Choose the integration that will hold the sync. Choose one with the same destination as your new sync, or select Create integration to create a new one (see Create or open an integration).
    An integration can only contain syncs that share the same destination application.
  3. Select Next to open the Create sync wizard.
Caution
  • You can't switch a sync's source to a different source type. NetSuite and NetSuite JDBC are different sources, so create a new sync instead.
  • Don't change a sync's connections to point at a different account or instance. Doing so can break the sync's dataset, schema, and table configuration.
  • To move to a different source or connection, create a new sync.
Step 1 - Configure the source application
  1. Choose a source - Select the source application that will provide data for the sync. Choose from any prebuilt, database, or universal application you can connect to, in the cloud or on-premises.
  2. Connect to the source - Select a connection, or select Create connection to make a new one (see Create a connection to an application). You can change your connection later, as long as the new connection points at the same account or instance.
  3. Set the sync-level schema drift policy - A schema drift policy defines how a sync responds when the shape of your source data changes — for example, when a column is added, removed, or its data type changes. Select Schema drift policy to review and modify the default settings for this source. This policy applies to every object or export you select in the following steps, unless you override it (see also Configure a schema drift policy).
  4. Select objects or exports to sync. Preview the results for the data available through your connection and select an export, object, or saved search name to choose which fields to sync. For the full field-level configuration within this step — choosing which fields to sync, naming the destination table, setting a primary key, and more, see the following articles for the exact steps:
    When merging tables, every source object requires at least one primary key. If you normalize a child object (preserving the array), you must set a primary key at each normalized array level for its destination table. If the child object is flattened, a primary key can be assigned at any level of the hierarchy.
Step 2 - Configure the destination application
  1. Choose a destination - Select the destination that will ingest and store all source data from the sync. For destination-specific details — including a table-name prefix for NSAW and the full data type mapping and reserved-word reference for each destination — see the following:
  2. Connect to the destination - Choose an established connection, or select Create connection to create a new one (see Create a connection to an application).
    Caution
    Avoid sharing connections with flows scheduled at the same time, as running them simultaneously can reduce performance.
Step 3 - Define sync settings
Name and describe your sync. Then, choose which email alerts to receive and what runs after the sync:
  • Sync error alerts — Get an email when the sync has errors.
  • Schema drift alerts — Get an email when the sync detects schema drift.
  • Next integration flow — Select the flows that run automatically after this sync completes.
  • Next sync — Select the syncs that run automatically after this sync completes.
For details, see Edit or view a sync’s settings. Next, decide how often the sync should run (see Schedule and run a sync for the full set of scheduling options).
What happens next
After you save your sync's settings, the wizard is complete, and you're returned to the sync's dashboard. The dashboard shows a "Ready to run" state — your sync is active, but hasn't loaded any data yet. Select Run to trigger the first run yourself, or wait for its next scheduled run.
Caution
Don't drop, rename, or recreate the tables or schemas that a sync creates and manages in the destination while the sync is active. If a managed table is missing, every later run of the sync fails at Transform with a "table not found" error, and a full resync doesn't recreate it.
  • If a table was dropped, recreate it with the same structure before the next run, or change the dataset's table name. The sync's Event logs hold the original CREATE TABLE statement and any later ALTER statements you need to rebuild it.
  • To start over, use the sync's own options instead of dropping tables by hand.
Learn more
