Create an MCP connection from an AI agent
You can connect one or more MCP servers to an AI agent to extend its capabilities. Once connected, the agent can use the tools, resources, and prompts exposed by the selected MCP server at runtime.
Before you begin, make sure you have:
Only enabled MCP servers appear in the list of available connections.
Perform the following steps to create an MCP connection while creating an agent:
  1. In the Add capabilities page, on the top of the page select MCP connections.
  2. On the top right, click + Create an MCP connection to create a new connection. For setup details, see MCP server.
  3. In the General section:
    Enter a Name for the connection.
    (Optional) Enter a Description.
  4. In Application details:
    Enter the MCP URI. When you enter an https URL, Celigo checks the server's published authentication settings and pre-selects the authentication method in Configure authentication. See Connect to a remote MCP server by URL.
    (Optional) Add any required HTTP headers as key-value pairs.
  5. In Configure authentication, select an auth type and fill in the fields for that type:
    Token:
    1. Enter the Token.
    2. Use the Send token via dropdown to select how to send the token: HTTP body, HTTP header, or URL parameter.
    For security reasons, the token must be re-entered each time you edit this connection.
     OAuth 2.0
    1. In Client registration, keep Automatic when the server supports it. There is no OAuth 2.0 client, client ID, client secret, or Scope to enter. When the server can't support it, Automatic is disabled and Pre-registered client is selected.
    2. With Pre-registered client, select an OAuth 2.0 client, or select + to create one. (Optional) Edit Scope. For setup details, see Set up authentication for an MCP server.
    Custom
    1. In Custom encrypted fields, enter your credentials as a JSON object. These fields are encrypted at rest.
    2. (Optional) In Custom unencrypted fields, enter any additional fields as a JSON object.
  6. For OAuth 2.0, select Save & authorize, and then sign in to the vendor and approve. For Token and Custom, select Test connection to verify that Celigo can connect to the MCP server. If the test succeeds, select Save & close.
The connection is added to the MCP connections list.
The selected capabilities are added to the agent and are available whenever the agent runs. Expand the MCP Connection to see a list of tools, resources and prompts provided by the MCP.
Troubleshoot connection failures
If the connection test fails, verify that:
  • The MCP URI is correct and the server is reachable.
  • The authentication credentials are valid.
  • Any required HTTP headers are configured correctly.
  • The MCP server is running and accessible from integrator.io.
  • For an OAuth 2.0 connection, the status banner at the top of the form shows why authorization failed. See Connect to a remote MCP server by URL.
Available capabilities
An MCP server can expose one or more of the following capabilities:
  • Tools – Allow the agent to perform actions or retrieve information from connected systems.
  • Resources – Provide read-only reference files, such as schemas, lookup tables, configuration files, or policy documents, that the agent can use to answer requests. Resource files must be smaller than 3 MB.
  • Prompts – Reusable prompt templates that standardize how the agent performs common tasks.
The capabilities available to an agent depend on what is configured and enabled on the connected MCP server.
Select MCP capabilities
After you create the connection, choose the capabilities the AI agent can access.
  • Tools
  • Resources
  • Prompts
  1. Expand the MCP connection.
  2. Select the required:
  3. Click Save.
Only the selected capabilities are available to the AI agent at runtime.
Restricting access to only the capabilities an agent needs helps improve security and ensures predictable agent behavior.
Manage an MCP connection
After you add an MCP connection, you can manage it from the Tools & capabilities section of the agent.
  • Select the Settings (⚙️) icon to configure a capability.
  • Select the Delete icon to remove a capability from the agent.
Removing a capability from the agent does not remove it from the MCP server.
Troubleshooting
I can't find my MCP server
Verify that the MCP server is enabled in AI Studio > MCP servers. Disabled servers are not available for selection.
I don't see all the expected tools, resources, or prompts
Check that the required capabilities are configured and enabled on the MCP server. If they were recently added or updated, refresh the page and reopen the connection.
The agent can't access a resource
Verify that:
  • The resource still exists in Celigo File Storage.
  • The file size is less than 3 MB.
  • The resource is enabled on the MCP server.
