Set alerts for long-running flows
Long-running flow alerts let you proactively monitor flows that run longer than a limit you set. These alerts inform you about unexpected delays as soon as they happen — even when you're away from integrator.io — instead of hearing about them from a downstream partner or catching them during a manual dashboard check. They're available on every integrator.io plan at no additional cost, for both integration app and custom flows. Setting one up doesn't affect the flow itself — it only monitors the flow's run time and notifies the recipients you choose.
Prerequisites
  • Permissions – You need Account Owner, Admin, Manage all, Custom Manage, Monitor all, or Custom Monitor access to the integration. A Monitor-level user can create an alert but can only add themselves as a recipient; see Manage long-running flow alerts for the full permissions table.
  • A flow to alert on – The flow doesn't need any prior run history to create an alert, but limit guidance (a suggested value and a historical runtime chart) only appears once the flow has completed runs to draw from.
A single flow alert
You can receive long-runtime alert emails when a specific flow runs longer than the limit you set. To set one limit for all flows in an integration at once instead, see All flows (integration) alert.
Create the alert
  1. Open the integration that contains the flow.
  2. Select the Alerts tab.
    The Alerts tab was previously named Notifications. Your existing Notify me of flow errors and Notify me when a connection goes offline settings are unchanged and still appear at the top of this tab.
  3. In the Long run time alerts section, select Create.
  4. In the Flow field, select the flow you want to alert on.
  5. Under Get an alert when this flow runs longer than, enter a limit in Hours and Minutes.
    As you enter a value, integrator.io shows how many of the flow's past runs would have triggered an alert at that limit — for example, "6 of 90 runs in the last 30 days would have triggered." Use this to check whether your limit is too tight (too many past runs would have triggered it) or too loose (it wouldn't have caught a run you consider a problem) before you save. The minimum value is 5 minutes.
  6. Optional: Select a different look-back period, and review the suggested limit and historical runtime chart to help you choose a value instead of entering one from scratch. See Historical runtime chart and limit guidance for how to read this section.
    If the flow is new or hasn't run enough times in the selected period, no suggestion appears. Enter a limit manually — you can revisit it later once the flow has more run history.
  7. Under Recipients, add at least one person to notify when the alert triggers. A recipient must be added before you can save the alert.
  8. Select Save alert.
A long-runtime alert doesn't cancel, pause, or otherwise change how the flow runs. To stop a run that has triggered an alert, use the Cancel run action from the Running flows dashboard or Run console.
How integrator.io monitors a flow run by set limit
Once saved, integrator.io monitors the flow's in-progress runs against your limit. If a run exceeds the limit, an alert indicator appears on the Running flows dashboard, in Run history, and in the Run console, and each recipient receives an email.
For a multi-instance flow, integrator.io monitors and alerts on each instance separately, using the same limit. For a multi-source flow, one limit applies across all sources. see Multi-source and multi-instance flows.
An integration-wide long-runtime alert default applies one runtime limit to all flows in an integration, including flows you add later, so you don't have to configure an alert on each flow individually. To alert on a single flow instead, see Set up a long-runtime alert on a flow.
Use an integration-wide default when you manage many flows and want a baseline safety net, then set a tighter or looser limit on individual flows that need one.
Set an integration-wide default
  1. Open the integration.
  4. In the Flow field, select All flows.
    The suggested limit, typical runtime range, and historical runtime chart aren't available at this scope, because a single limit is being applied across flows with different normal run times. Enter a value based on your own knowledge of the integration. A low limit can trigger alerts for flows that are running normally, so start with a conservative value and narrow it later using per-flow overrides.
  6. Under Recipients, add at least one person to notify when the alert triggers.
  1. Select Save alert.
Once saved, every flow in the integration — including flows added afterward — is monitored against this limit, except for flows that have their own alert (see below).
How per-flow overrides work
A limit set directly on a flow always takes precedence over the integration-wide default for that flow. A flow can't carry both a default-inherited limit and its own limit at the same time — setting one on the flow replaces the default for that flow only; every other flow in the integration keeps using the default.
To override the default for one flow, follow the steps in Set up a long-runtime alert on a flow and select that specific flow instead of All flows.
  • Multi-source flows – integrator.io monitors each source run individually, but a multi-source flow uses a single limit across all of its sources; you can't set a different limit per source. The historical runtime chart isn't shown for multi-source flows, because runtimes across sources can vary too widely to chart meaningfully.
  • Multi-instance flows – Each instance generated from the multi-instance flow is monitored and alerted on separately, using the same limit.
When you create a long-runtime alert on a single flow, integrator.io shows a suggested limit, a typical runtime range, an estimated trigger frequency, and an expandable historical runtime chart, so you can pick a limit based on the flow's own run history instead of guessing. This reference explains what each of these values means and when they're available.
Limit guidance
This guidance appears only when you're creating or editing an alert on a single flow. It isn't available for an integration-wide default or for a multi-source flow — see All flows (integration) alert for why.
Reference
Element Description
Look-back period – Determines which runs the guidance below is calculated from. Provides values for instance: Last 24 Hours, Last 7 Days, Last 30 Days, Last 90 Days to decide your limit. Default: Last 30 Days.
Changing the period recalculates the suggested limit, typical range, trigger frequency, and chart.
Suggested limit – A single recommended value for the limit field, based on the flow's runs in the selected period. Suggests based on calculations from this flow's own run history in the selected period. Selecting the suggestion fills in the Hours and Minutes fields; you can still adjust the value afterward.
Typical runtime range – The range of run times integrator.io considers normal for this flow in the selected period. Provides a typical range based on calculations on this flow's run history
Estimated trigger frequency – How many of the flow's past runs in the selected period would have triggered an alert at the limit you've entered, shown as "X of Y runs." Updates live as you change the limit or the look-back period. Use it to check whether a limit is too tight (a high count) or too loose (a count of zero when you expected some) before saving.
Historical runtime chart – An expandable chart plotting the flow's run times over the selected period. Provides visual detail behind the suggested limit and typical range. Not available for multi-source flows or for an integration-wide ("All flows") alert.
No guidance
If a flow is new, or hasn't run enough times in the selected look-back period, integrator.io doesn't show a suggested limit, typical range, or chart. Enter a limit manually. Once the flow has more run history, either edit the alert to see updated guidance, or select a longer look-back period.
Related articles
