Add content-based routing in your VAN connection
Content-based routing (CBR) decides which flow in integrator.io receives each electronic data interchange (EDI) document that arrives from the value-added network (VAN). All inbound documents from your trading partners reach integrator.io through a single VAN connection, so a routing rule must match every document type your partners send — including acknowledgments such as 997, 824, and CONTRL.
This article is for B2B Manager builders who receive EDI documents through ECGrid. It explains how inbound VAN documents are routed, how to write routing rules in your VAN connection that covers every document type, how to route documents to exports in the same flow or in different flows, and how to fix inbound documents that stop arriving because a routing rule is missing.
Prerequisites
How inbound VAN documents reach a flow
integrator.io routes each inbound VAN document through the same stages. The VAN connection is the only entry point for documents from ECGrid, so every inbound flow in the environment shares it.
  1. ECGrid delivers the document. Your trading partner sends the document to the VAN. ECGrid delivers it from your mailbox to integrator.io over AS2.
  2. integrator.io identifies the connection. The sender and receiver IDs on the message identify your VAN connection and environment. You can create only one VAN connection per environment, and each environment has its own ECGrid mailbox.
  3. The routing rules read the content. integrator.io passes the message to the routing script on the VAN connection. The script inspects the content — for example, the transaction set ID in the ST segment — and returns the flow ID and export ID that should process the document.
  4. The matching flow runs. integrator.io sends the document to the listener in the flow that the script returns.
If the routing script doesn't return a valid flow ID and export ID for a document, integrator.io rejects that document. ECGrid treats the rejection as a failed delivery and retries at intervals.
Why every document type needs a routing rule
Every document type that ECGrid can deliver to your mailbox needs a matching condition in your routing script, even if you don't process that document type. Routing rules don't skip unmatched documents — an unmatched document is rejected and redelivered.
Example: You build a flow for a trading partner's 850 purchase orders and write a routing rule for ST*850* only. A trading partner also sends 824 and 997 documents in response to your invoices. Those documents have no matching rule, so integrator.io rejects them and ECGrid keeps retrying delivery. Your 850 orders stop arriving until you add rules for the 824 and 997 documents.
Every routing rule must return a flow ID and export ID, so each document type needs a flow to receive it. For acknowledgments or other documents your business doesn't act on, create a flow that only receives the documents. The flow accepts the document so integrator.io doesn't reject it, and ECGrid stops retrying. You can route several unused document types, such as 997, 824, and CONTRL, to the same flow.
What are example scenarios for routing VAN documents
Example scenario 1: Routing different document types to the same trading partner flow
Example: A trading partner sends 850 purchase orders and 860 purchase order changes. Both create or update sales orders in NetSuite, so you build one flow, TP orders to NetSuite, with two VAN listeners: one for 850 documents and one for 860 documents. Your routing rules return the same flow ID for both document types, and a different export ID for each listener.
Route document types to different listeners in the same flow when they share the same downstream processing — for example, when they update the same records in the same destination application. Use this scenario when you want to manage, schedule, and monitor related document types together in one flow.
Example scenario 2: Routing different document types to different trading partner flows
Example: A trading partner sends 850 purchase orders and 860 purchase order changes. You sync purchase orders to NetSuite sales orders, and you sync purchase order changes to Shopify orders. You build two flows, each with its own VAN listener. Your routing rules return a different flow ID and a different export ID for each document type.
Route document types to listeners in different flows when each document type needs its own processing or goes to a different destination application. Use this scenario when document types have different mappings, destinations, or schedules, or when you want an error in one flow to stay separate from the others.
How to find the document types you receive
Before you write routing rules, list every document type that your trading partners send to your ECGrid mailbox.
  1. Sign in to ECGrid.
  2. Go to your ECGrid mailbox, select Transactions.
    Note each inbound transaction set ID, such as 850, 860, 824, or 997, and each EDIFACT message type, such as ORDERS or CONTRL.
  3. Review each trading partner's EDI implementation guide for document types they send that don't appear in your transaction history — for example, acknowledgments for outbound documents you plan to send.
How to write routing rules for your document types
You can write routing rules within the VAN connection using the content-based flow router function stub that Celigo provides. The script receives each inbound message and returns the flow ID and export ID of the flow that should process it.
Use the function stub to create your script
  1. From the left navigation, go to Resources > Connections.
  2. Open your VAN connection.
  3. Under Configure routing for shared connections, in the Routing rules editor, select Launch.
  4. In the Routing rules editor, click the + sign to create a new script.
  5. In Create script,
    1. Enter a name for your script.
    2. In Insert function stub, select Content-based flow router.
    3. Click the expand icon (Expand Window.svg) to open the script editor, then edit and save the content..
    4. Click Save and close.
If you have several document types within a single file, see Use Celigo file storage as a staging area to split multi-document EDI files.
contentBasedFlowRouter function stub
You can use this stub to create a script and route, for example, 850 purchase orders and 860 change orders to their own flows, and route 997, 824, and CONTRL acknowledgments to one receive-only flow. It reads the element separator from the ISA segment, so it works when a partner uses a separator other than *.
 * contentBasedFlowRouter stub:
 * The name of the function can be changed to anything you like.
 * The function will be passed one 'options' argument that has the following fields:
 * 'httpHeaders' - A JSON object containing the HTTP headers received in the request from the trading partner.
 *   Example: { as2-from: 'OpenAS2_appA', as2-to: 'OpenAS2_appB' }
 * 'mimeHeaders' - A JSON object containing the MIME headers from the MIME part containing the EDI message.
 *   Example: { content-type: 'application/edi-x12', content-disposition: 'Attachment; filename=rfc1767.dat' }
 * 'rawMessageBody' - A String containing unencrypted EDI/XML content.
 * The function needs to return an object containing '_flowId' and '_exportId' as properties
 * of the flow that should be run.
 * To signal a failure, throw an exception.
function contentBasedFlowRouter(options) {
  let returnObj = null;
  if (options.rawMessageBody.includes('ST*850*')) {
    // Provide the condition, e.g., 'ST*850*'
    returnObj = {
      _flowId: "<_flowId>",    // flow_id is required for downstream processing.
      _exportId: "<_exportId>" // the '_id' of the listener that should be run.
  } else {
    returnObj = {
  return returnObj;
You can replace each placeholder with the flow ID and export ID from your account. After creating your script, check if the routing rules work as required.
The routing script returns one flow ID and one export ID for each message. It doesn't split a message that contains several document types. If one interchange holds functional groups with different document types, the example routes on the first `ST` segment only.
How to check if the routing rules work
To check if the routing rules work,
  1. In the Routing rules editor under Script enter the name of the script you created in the earlier section. Click the pencil icon to edit it. In the Script editor that opens, you will now see Function input and Function output sections.
    Note that you cannot see these windows when you first create the script.
  2. Paste a sample options object or enter the headers yourself into Function input. (For live documents, integrator.io fills them in from the inbound message.) This sample options object contains a trading partner 850 purchase order:
      "httpHeaders": {
        "as2-from": "<ECGrid_AS2_ID>",
        "as2-to": "<your_mailbox_AS2_ID>",
        "content-type": "application/pkcs7-mime"
      "mimeHeaders": {
        "content-type": "application/edi-x12",
        "content-disposition": "attachment; filename=PO12345-850.edi"
      "rawMessageBody": "ISA*00*          *00*          *ZZ*TPTEST         *ZZ*YOURCOMPANY    *260923*1200*U*00401*000000101*0*P*>~GS*PO*TPTEST*YOURCOMPANY*20260923*1200*101*X*004010~ST*850*0001~BEG*00*SA*PO12345**20260923~PO1*1*10*EA*4.99**VP*SKU-100~CTT*1~SE*5*0001~GE*1*101~IEA*1*000000101~"
    To test the 860 condition, replace the rawMessageBody value with an 860 document:
    "rawMessageBody": "ISA*00*          *00*          *ZZ*TPTEST         *ZZ*YOURCOMPANY    *260923*1200*U*00401*000000102*0*P*>~GS*PC*TPTEST*YOURCOMPANY*20260923*1300*102*X*004010~ST*860*0001~BCH*01*SA*PO12345**20260923~POC*1*CA*10*5*EA*4.99**VP*SKU-100~CTT*1~SE*5*0001~GE*1*102~IEA*1*000000102~"
  3. Check the routing rules in your script. Note that the function input has the same structure in both example scenarios. Only the routing rule is different, and so the output changes.
  4. Then, select Preview, and check Function output. When you preview each sample, Function output shows these results. In scenario 1, the flow ID stays the same and only the export ID changes. In scenario 2, both IDs change.
    Sample Scenario 1 output Scenario 2 output
    850 purchase order _flowId: <tp_orders_flowId>, _exportId: <850_listener_exportId> _flowId: <netsuite_orders_flowId>, _exportId: <netsuite_orders_listener_exportId>
    860 purchase order change _flowId: <tp_orders_flowId>, _exportId: <860_listener_exportId> _flowId: <shopify_changes_flowId>, _exportId: <shopify_changes_listener_exportId>
    Any other document type, such as 997 Error: No routing rule for this document type. Error: No routing rule for this document type.
FAQ: What to do when inbound documents stop arriving from ECGrid
When a document type has no routing rule, ECGrid can't deliver it, and documents you expect — such as purchase orders — stop reaching integrator.io.
Symptoms
  • Inbound documents, such as 850 purchase orders, stop appearing in your flows, and no new data arrives in integrator.io.
  • Documents in your ECGrid mailbox stay in a pending or retry status, and no MDN (message disposition notification) is returned.
  • Resending or reprocessing a document from ECGrid doesn't deliver it.
  • An invalid flowid error appears for 824, 997, or other document types.
Cause
The routing script on the VAN connection has no condition for one or more document types that ECGrid delivers. integrator.io rejects those documents, and ECGrid retries them at intervals. Clearing individual stuck documents in ECGrid doesn't fix the problem, because the next document of the same type is rejected again.
Resolution
  1. List every inbound document type in your ECGrid mailbox. For steps, see the Identify the document types you receive section in this article.
  2. For each document type your business doesn't process, create a receive-only flow, or route it to an existing one.
  3. Open the Routing rules editor on your VAN connection, and add a condition for every document type.
  4. Preview the script with a sample of each document type, and then save the connection.
  5. Contact Celigo support to have the documents stuck in your ECGrid mailbox released or resent.
    Include the ECGrid ticket number, if you have one, and the first ISA segment of an affected document.
  6. Confirm that the stuck documents arrive in the correct flows.
Prevention
  • Before you send a new outbound document type, add routing rules for the acknowledgments your partner returns, such as 997 or 824.
  • Before you onboard a new trading partner, review their implementation guide for every document type they send.
  • Preview your routing script with a sample of each document type whenever you add a flow that uses the VAN connection.
Learn more
