After you create a connection to the VAN (value-added network), you can connect with trading partners and create flows to export and import data. If you configure multiple flows, imports, or exports, the data is shared with the corresponding trading partners based on the unique AS2 ID.
To create a simple EDI flow, see Configure EDI listener and import steps.
Make sure that you configure your ECGrid account before you run the flow.
