Delete a flow when you no longer need it. The flow goes to the Recycle bin for your data retention period, so you can restore it with its configuration intact if you change your mind. The exports, imports, scripts, and connections the flow used stay in your account, because other flows may share them. This article covers checking what the flow shares, deleting it, and restoring it.
Prerequisites: You must have Manage permissions for the integration; see Manage user roles & permissions to an account. You can't delete a flow while it's running; wait for the run to finish or cancel it, and turn the flow off. See Cancel a flow run.
Check what the flow shares
A flow's steps can be used by other flows (see Reuse an existing flow step). Deleting the flow doesn't delete those steps, but if you then delete the steps themselves, every flow that uses them is affected.
- Go to Home
, open the integration, and then select Flows.
- Select the flow's Actions
> Used by to see where its resources are used.
Delete a flow
- Go to Home
- In the flow's row, turn off Enabled
. Delete flow isn't available while the flow is on.
> Delete flow.
The flow moves to the Recycle bin, where it stays for your data retention period — 30 days by default — before it's purged; see Delete a resource and Retain your log and error data for more than 30 days. Clones and downloaded copies aren't affected.
To delete the flow's exports, imports, or other resources as well, delete each one from Resources after removing its other references; see Delete a resource.
Restore a deleted flow
- Go to Resources
, and then select Recycle bin.
> Restore.
The flow returns to its integration, turned off. Turn it on when you're ready for it to run again; see Run a flow.
