The Review changes panel opens during a pull or revert. It lists every resource the operation affects, with an action label that shows whether each resource will be updated, added, or removed. Use this reference to understand what each panel feature does, what each action label means, and what to expect for each resource type before you complete a pull or revert.
To open the panel, see Pull changes from one integration to another or Revert changes. To use the panel you need Manage access to the integration, or you're an account owner or administrator. See Manage user roles & permissions to an account.
Panel layout
- Header — The panel title with the conflict count (for example, 0 conflicts), Expand all, and Revisions guide. Revisions guide opens in a new tab. During a revert, the header has no conflict count.
- Resource groups — Changes are grouped by resource type, for example imports, flows, and integrations. Groups are collapsed by default. Select a group heading to expand or collapse it.
- Resource rows — Each row shows the resource name, its Action label, which opens the diff in a full-size view. Each row can also show References.
- Diff — A side-by-side comparison labeled Before pull and After pull. During a revert, the labels are Before revert and After revert. Removed lines are highlighted in red and added lines in green.
- Collapsed lines — Unchanged lines between changes are collapsed behind Expand N lines ... links. Select Expand N lines ... to show those lines.
- Footer — Next continues to the next step. In a pull, it opens the Merge changes panel. In a revert, it opens the Revert changes panel. Close closes the panel.
Panel features
Conflict count
The conflict count shows how many conflicts the pull contains. You can't continue a pull until it shows 0 conflicts. Reverts never create conflicts, so the count doesn't appear during a revert. To clear conflicts, see Pull changes from one integration to another.
Refresh
Select next to the conflict count to reload the panel. Changes you make to the integration after you create the pull don't appear until you reload, so reload before you merge to include them. It's most useful when you edit the integration in one browser tab and keep Review changes open in another.
Expand all
Select Expand all to expand every resource row at once. The label changes to Collapse all, which collapses every row again.
References
Resource rows for shared resources, such as exports, imports, and scripts, show References. Select References to see every integration and flow in your account that uses that resource. For example, if the pull includes an export named "Export all Salesforce leads," References lists every integration and flow that uses that export.
Changing a shared resource, such as an import, export, or script, changes it everywhere it's used, not only in the integration you're pulling into. Check References before you complete a merge that includes removals or script changes.
When you open a shared resource to edit it, a Proceed with caution banner appears at the top of the editor and shows how many places use it. Select Used by in the banner to review all references before you save.
Action labels
The Action label shows what happens to a resource when the pull or revert completes. In a pull, the current integration is the one you change and the remote integration is the one you pull from. In a revert, the comparison is between the integration's current state and the revision you select.
| Action | Meaning |
| Update | The resource exists in both integrations, and the remote version has changes that the pull applies to the current integration. |
| New | The resource exists in the remote integration but not in the current integration. The operation adds it to the current integration. |
| Removed | The resource exists in the current integration but not in the remote integration. The operation removes it from the current integration. |
| Deleted | A flow no longer exists in the remote integration. It works like Removed for other resource types. |
If a resource you expect as Update appears as Removed paired with New, don't continue. See Troubleshoot ILM revision and pull issues.
Resource scenarios
Updated resources
A modified resource appears with Update. The panel shows the fields that changed, for example an export whose HTTP method changed from POST to GET, or whose relative URI now includes a date variable. Each change shows a few unchanged lines for context.
New resources
A resource that exists only in the remote integration appears with New. The merge adds its full definition to the current integration. If the new resource uses a connection that doesn't exist in the current environment, the operation adds a connection step. See Pull changes between integrations or Revert changes.
Removed and deleted resources
A resource removed from the remote integration appears with Removed, or Deleted for flows. Completing the merge removes the reference to the resource from the current integration's flows. It doesn't delete the resource from your account, so exports, imports, and scripts that other integrations use keep working.
Mixed actions in one pull
A pull can include resources with different action labels. Each resource row has its own label. Review every row before you merge.
Review API changes
When a pull or revert includes API changes, an APIs group appears. Each API entry shows field-level differences, with fields highlighted as added, updated, or removed, rather than the whole API as a delete-and-add pair.
- If a pull or revert would create a route, method, and version combination that already exists in the destination integration, integrator.io increments the API version automatically. For example, v1 becomes v1.1.
- When you pull between environments, the panel can show an API version change even when no API changed. See Troubleshoot ILM revision and pull issues.
Scripts
Scripts are often shared across integrations and flows, so they behave differently from other resources in the panel.
- Removing a script from a flow removes the reference to it from that flow. It doesn't delete the script from your account.
- Changing a script in one integration changes it in every integration and flow that uses it.
- When a pull both modifies and removes a script, the panel highlights the removal separately from the modification. The pull removes the script from the flow but not from your account.
What the panel doesn't show
- Lookup cache data. The panel shows lookup cache references only. See ILM supported resources and limits.
- Topic messages. The panel shows topic configuration changes only. See ILM supported resources and limits.
- Flow diffs use JSON names. A flow's diff shows exports under pageGenerators and imports under pageProcessors. See Integration Lifecycle terminology.
