Data Flow: NetSuite Fulfillment to Shopify Fulfillment Add
Error Code: 404
Error Message: '{"errors":"Not Found"}'
Reason: Occurs when an eTail Order line ID is changed.
Resolution:
- Goto NetSuite, then locate your Order ID and navigate to the fulfillment record from the Order ID record.
- Click Edit.
- Check for the "eTail Order Line ID" at line level.
- Provide a valid ID and Save the record.
- Go to the integrator.io dashboard and open the Error dialog of the job.
- Select the Job and click Retry to re-run the Fulfillment flow successfully.
