Create your first integration
An integration groups one or more flows, APIs, tools, or topics that move and transform data between systems. An integration can hold a single flow, API, tool, or topic, or a set of them grouped in a folder. On the Home page, each integration appears as a tile in the tile view or as a row in the list view. You can group flows into integrations however you like. This article shows you how to create and view an integration.
Note: A topic can be registered to more than one integration.
See also key integration concepts and integration-related terms.
Prerequisites
Create an integration
You can create an integration to group related flows, tools, APIs, and topics in one place. You can move any flow or API to a different integration at any time.
Use the following steps to create an integration:
  1. On the Home page at the top right, select Create > Integration.
  2. Give your integration a name and an optional description.
  3. Select Save.
    Your first integration is now created. You can view the integration on the Home page.
    To create flows, tools, APIs, and topics in your integration, see Create custom flows, Create and manage APIs using API builder, Introduction to Celigo tools, and Create and manage topics.
View your integration
You can view your integration either as a tile in the default tile view or as a row in the list view. These views are only available on the Home page.
In the tile view, you can drag and drop an integration using the dots icon in the upper-left corner of the tile. The drag-and-drop feature is useful when you have many integrations and want to move them around based on your priorities.
In the list view, you can pin and unpin an integration. The pin/unpin feature is useful when you have many integrations but want to view select priority integrations at the top of the list. You can also view the applications that are a part of the integration folder.
From the Home page, in both views, you can perform actions like cloning, downloading, or deleting the integration.
