Use the Analytics tab within an integration to view errors, successes, ignores, and average processing time per successful record over time in visual charts. This can help you spot patterns or trends and take action accordingly.
Use the selection button on the top right to select up to eight data streams to include in the charts (for example, one integration-level data stream and seven individual flows' data streams).
The charts summarize the results of flow runs that occurred in the timespan you select:
- Last 4 hours or less: Results displayed within a minute interval
- 4 hours to 4 days: Results displayed within an hourly interval
- More than 4 days: Results displayed within a daily time interval
Note: Although you can view the flow statistics for the past year, the error retry data is available for each flow step only for the past 30 days or the most recent 20,000 errors, whichever occurs first.
