In an integration, the Flows, APIs, Tools, and Topics tabs list the resources registered to that integration, complete with each resource's status and management actions. Each tab shows only the current integration's resources — not every flow, API, tool, or topic in your account. This article is a reference for what each column shows and what each action does; the articles it links to explain how to build and configure the individual resources.
To open a tab, go to Home , open the integration, and then select Flows, APIs, Tools, or Topics from the top of the screen.
Every tab has a search box, and you can sort the list by selecting a column heading. Last updated and Last run follow the date and time format in your account profile; see Change your email, time zone, and profile settings.
Flows
The Flows tab opens by default when you open an integration. In Flows, select Create to add a Flow, a Multi-instance flow, or a Data loader flow for importing data files into NetSuite, Salesforce, or any other RESTful application. Learn how to create a new flow. If the integration uses flow groups, they're listed under Flow groups on the left (see Organize flows and APIs into groups for more information).
| Column | What it shows |
| Name/Description | The flow's name and description. Select the name to open the flow. |
| Errors | Success when the flow has no open errors, or the count of open errors. Select it to open the flow's errors; see Errors page. |
| Last updated | When the flow was last changed. |
| Last run | When the flow last ran. |
Mapping |
Opens the flow's import mappings. If you don't have any mappings, you'll see Add mapping. If you have an existing mapping, you'll see Edit mapping. A flow with several import steps asks which step's mapping to open. Learn more about mapping. |
| Schedule | Opens the flow's schedule. Flows that run in real time, including flows that listen to a topic, show Realtime instead. The schedule can't be edited until every step in the flow is configured or removed. Learn how to schedule or run flows. |
| Run |
Runs the flow now, regardless of its schedule. A flow that only listens to a topic runs whenever a message is published, so it has no schedule and can’t be run from this tab. See Subscribe a flow to a topic. |
| Enabled | Turns the flow on, so it runs on its schedule, or off, so it doesn't run. You can turn one flow off without stopping the rest of the integration. |
Actions |
The actions in the next table. |
Actions
Select Actions in a row to open these options.
| Action | What it does |
| Edit flow | Opens the flow in Flow builder. |
| View audit log | Shows the audit log for this flow. The integration's own audit log is on its Audit log tab. |
| Used by | Shows whether the flow or its resources are used elsewhere. Check this before you delete a flow so you don't remove it from another integration that uses it. |
| Clone flow | Copies the flow into the same or a different integration or environment. See Clone a flow. |
| Download flow | Saves the flow as a ZIP file that another user can install, where it becomes part of a new integration. The ZIP includes the configuration of any topics the flow uses, but not their messages. |
| Move flow | Moves the flow to another integration, optionally into one of its flow groups. See Move a flow to another integration. |
| Delete flow | Deletes the flow and sends it to the Recycle bin for your data retention period. See Delete a resource. |
APIs
The APIs tab lists the APIs registered to the integration. Select Create > API to build one; see Create and manage APIs using API builder. Create > Create API group adds a group; see Organize flows and APIs into groups.
| Name | The name you gave the API. |
| Version | The API's version, which is part of its URI: https://api.integrator.io/apis/<version>. You can change it in the API's settings in API builder. |
| HTTP method | The method you chose for the API request. |
| Relative URI | The URI you configured for the API request, relative to https://api.integrator.io/apis/<version>. Query parameters aren't shown. |
| Last updated | When the API was last changed. |
Two enabled APIs in your account can't share an endpoint URL; see Invoke an API and API limits.
Actions
| Edit API | Opens the API in API builder. |
| View request logs | Shows the API's request logs. |
| View audit logs | Shows the API's audit logs. |
| Push to APIM or View in APIM | API Management only. Pushes the API to your API console so you can configure and publish it. An APIM label appears next to pushed APIs. |
| Download OpenAPI spec | Downloads the OpenAPI specification that integrator.io generates for the API. |
| Download API | Downloads the API. |
| Copy cURL | Copies a cURL command that invokes the API. Available only after you've configured the API request. |
| Add to MCP server | Adds the API to an MCP server. See Create MCP servers. |
| Clone API | Creates a copy of the API. |
| Move to integration | Moves the API to another integration. |
| Delete API | Deletes the API and sends it to the Recycle bin for your data retention period. |
| Used by | Shows the resources that use, or are used by, the API. |
| Disable API | Stops access to the API, for example while you test or retire it. Disabling an API affects anyone who relies on it. |
Tools
The Tools tab lists the tools registered to the integration. Select Create tool to build one; see Create a tool.
| Name | The name you gave the tool. |
| Last updated | When the tool was last changed. |
Actions
| Edit tool | Opens the tool in Tool builder. |
| View audit logs | Shows the tool's audit logs. |
| Used by | Shows the resources that use, or are used by, the tool. |
| Delete tool | Deletes the tool and sends it to the Recycle bin for your data retention period. |
Topics
The Topics tab lists the topics registered to the integration. Select Create topic to create one, or Register existing to add a topic that's already in your account. A topic also registers itself when you select it in a flow step and save the step.
| Name/Description | The topic's name and description. Select the name to edit the topic. |
| Last updated | When the topic was last changed. |
| Retention | How long the topic keeps each message. Messages are deleted after this period whether or not they've been read. |
| View messages | Opens Message history, where you can filter and view messages or select Purge messages to delete all of them. A purge can't be undone. See View and purge a topic's message history. |
| Edit topic | Changes the topic's name, description, or retention period. See Create and manage topics. |
| View audit log | Shows the changes made to the topic. |
| Used by | Shows the flows that publish to or listen on the topic. |
| Deregister | Removes the topic from this integration without deleting it. You can't deregister a topic while a flow in this integration uses it. See Grant access to topics. |
