Error code: "invalid_key_or_ref"
| Flow impacted |
Error code/ Message |
Likely cause | Resolution |
| Shopify Order to NetSuite Order Add |
invalid_key_or_ref Failed to add Shopify Order #1011. Invalid entity reference key 35007 |
This error indicates that the particular customer that is referencing, reference key 35007, is no longer an Active Customer. |
invalid_key_or_ref Failed to add Shopify Order #1234. Invalid item reference key 1009 for subsidiary 1. |
A subsidiary of the Item record in NetSuite does not match with the Subsidiary on the Customer record. |
invalid_key_or_ref Failed to add Shopify Order #1234. Invalid shipmethod reference key 4115 for entity 33676. |
A subsidiary of the shipping method does not match with the Subsidiary of the Customer. |
| Shopify Transaction to NetSuite Customer Deposit Add |
invalid_key_or_ref Failed to create Customer Deposit for Shopify Order XXXXXX due to Invalid reference key of Order XXXXXX for Customer XXXXXX. |
If you map the payment method on the sales order, NetSuite restricts to a create customer deposit. |
| Shopify order to NetSuite order (cash sale or sales order) |
Failed to add/update customer for Shopify order T******T. Failed to save record because Invalid custrecord_celigo_shopify_store reference key 1. (OR) Failed to save record because Invalid custrecord_celigo_shopify_store reference key 1. |
The error indicates that the flow is not detecting the store ID or the store sync did not update the new store ID if there had been changes. |
Make sure that the store ID is matched between the Shopify, Netsuite, and the one set in integrator.io. To find store ID in integrator.io:
