Invite and manage users to an account or integration
This article explains how to add, manage, or remove user access to your Celigo integrator.io account or environments within your account, if you have production and non-production environments. An account owner or administrator (admin) can add users, remove users, or change user permissions. You can delete your account if you no longer use the Celigo platform.
An account owner or admin can grant invitations permission to non-admins (users with manage or monitor roles) so that they can invite others to an integration with a role that is the same or less than theirs. The Invitations feature is enabled, by default, in new accounts. As required, the admin can disable/enable it.
An account owner or admin can also grant Celigo Support access permission to non-admins so that they can give Celigo Support access, if required, for troubleshooting issues. They can also revoke/disable access.
The sections below provide tasks that the account owner/admins and non-admins can perform for users in an account.
Account owners or admins
You can invite and manage users with different roles and permissions to your account. Based on your requirements, delete users or in rare instances, delete account.
Invite users to your account
  1. Sign into integrator.io as an account owner or admin, click the avatar icon in the upper right corner of integrator.io, then click Users.
  2. At the top right, click + Invite user.
  3. Enter the new user’s email address, and configure the permissions.
  4. Click Save.
The user receives an email with a confirmation link that takes them to the sign in page.
Users must set up a profile with their email address to access any account in that domain. If a user must access a US integrator.io account AND an EU integrator.io account (eu.integrator.io), they must create a profile associated with their email address in both domains.
  • If you invite a user who does not yet have an existing Celigo account, the link will take them to the integrator.io sign up page. After they create their profile, they will have access the account you invited them to.
  • An NA (integrator.io) user who is invited to an EU (eu.integrator.io) account must establish an EU account before accepting the invitation, and vice versa. The same email address is acceptable in both instances simultaneously.
Manage users
  2. Click the Actions overflow menu next to the user and select Manage user to modify permissionsin your account or environments in your account.
Remove users
  2. Click the Actions overflow menu next to the user and select Remove user from account if you have only a production environment or Remove user from environment if you also have non-production environments in your account.
Delete your Celigo account
Use the following steps to permanently delete your account and remove all associated data:
  1. Delete all resources used by any flow or integration in your account.
  2. Delete all integrations and flows in your account.
  3. Delete all user profiles and account information.
  4. Delete any remaining resources.
  5. Notify Celigo support of your request to delete your account and remove all associated data.
Non-admins
Non-admins can invite users to an integration if the admin grants invitation permission to them. They can invite users to an integration with roles and permissions that are equal to or less than theirs.
  1. On the Celigo platform Home page, select the integration in which you want to add users.
  2. In the integration, select the Users tab.
  3. Click + Invite user.
    Only when the admin grants Invitations permission, the + Invite users option is shown for non-admins, and they can invite new users to an integration. Otherwise, + Invite user is hidden, and non-admins can't invite users to an integration.
  4. In the Invite user form, search and select an existing user, or add a new user.
  5. Select either monitor or manage role for the user.
  6. If you'd like to secure access to the integration, then enable MFA for users.
  7. Click Save.
After you see the user added to the Users list in the integration, you can click Actions → Manager user. if this option shows for you and make any changes.
If the admin grants invitation permission , non-admins can also invite new users to an integration from a flow step Errors list when they assign errors for troubleshooting.
If the admin grants Celigo Support access permission, non-admins can give temporary access to Celigo Support for troubleshooting.
