The #and block helper renders one expression if both arguments have a non-empty value, and a fallback {{else}} expression if either argument is empty, null, or undefined. Note that the integer 0 is treated as absent even though it has a value -- but the string "0" is treated as present because it's a non-empty string.
Syntax
{{#and field1 field2}} expr {{else}} expr {{/and}}
field1, field2 -- Two fields or values to evaluate. Both must be truthy for the block to render. Required.
Examples
Render output when both fields are present
{{#and legends.unicorns legends.horses}}
{{legends.unicorns}} - {{legends.horses}}
{{else}}
Not found
{{/and}}
Input:
"legends": {
"unicorns": "11",
"ponies": "22",
"horses": "33",
"total": "66"
Output: 11 - 33
Render a full name when first and last name are both present
{{#and firstName lastName}}
{{firstName}} {{middleName}} {{lastName}}
{{else}}
Not found
{{/and}}
Input:
"firstName": "Hillary",
"middleName": "Ann",
"lastName": "Swank"
Output: Hillary Ann Swank
Falsy values that cause the {{else}} branch to render
| Value | Type | Evaluates as |
0 |
Integer | absent (empty) |
Empty string | absent (empty) |
null |
Null | absent (empty) |
undefined |
Undefined | absent (empty) |
"0" |
String | present (non-empty) |
Usage notes
- Both arguments must have a non-empty value for the block to render. If either is empty, null, or undefined, the
{{else}}expression renders instead. - The integer
0is treated as absent even though it has a value. The string"0"is treated as present because it's a non-empty string. - The
{{else}}clause is optional but recommended to handle missing or null field values gracefully. - Fields referenced inside the block (e.g.
{{middleName}}in the name example) don't need to have a non-empty value -- only the two arguments passed to#andare evaluated.
