#inArray helper
Checks if a specified value exists in an array. If the value is found, the main block is rendered; if not, the {{else}} block runs. This helper works only with simple arrays (strings, numbers, etc.), not arrays of objects.
Usage
{{#inArray array value}} expressionInitial {{else}} expressionElse {{/inArray}}
  • array (required): the array to search
  • value (required): value to check for
Examples
  1. Check if a tag exists in an order
    {{#inArray record.order.tags "priority"}}
      Push to Salesforce as high-priority case
    {{else}}
      Ignore or send as regular case
    {{/inArray}}
    Input:
      "record": {
        "order": {
          "id": 45678,
          "tags": ["gift", "priority", "international"]
    Output:
  2. Check membership with a missing value
    {{#inArray record.order.tags "express"}}
      Mark as express shipping
    {{else}}
      Continue with standard shipping
    {{/inArray}}
    Input:
      "record": {
        "order": {
    Output:
  3. Strings don't change to numbers
    {{#inArray record.numbers "3"}}  Found{{else}}  Not found{{/inArray}}
    Input:
    { "record": { "numbers": [1, 2, 3, 4] } }
    Output:
    Not found
  • Works only with arrays of simple values. For arrays of objects, use the #filter helper.
  • Matching is case-sensitive: "Priority" and "priority" are treated as different values.
  • Useful for routing, conditional branching, or handling special cases based on tags or labels.
  • Renders the {{else}} block if the array parameter is not a valid array or if the array contains objects.
