The #filter block helper iterates over an array and renders the block once for each element whose value or property matches a specified value. If no elements match, it renders an optional {{else}} block. Use it when you need to output properties of matching elements from an array of objects.
Syntax
{{#filter array value arrayProperty}} expr {{else}} expr {{/filter}}
array -- The array to filter. Required. If missing, undefined, or not an array, the helper produces no output and does not render the {{else}} block.
value -- The value to match against. Required. Matching is case-sensitive: "Custom" does not match "custom".
arrayProperty -- The property in each array element to compare. Optional. Required when array contains objects. Supports dot-paths (e.g., "details.department").
Examples
Filter line items by property value
{{#filter record.order.lineItems "custom" "tag"}}
Custom item: {{sku}}
{{else}}
No custom items
{{/filter}}
Input:
"record": {
"order": {
"lineItems": [
{ "sku": "TShirt-001", "tag": "standard" },
{ "sku": "Mug-009", "tag": "custom" },
{ "sku": "SmallMug-010", "tag": "custom" },
{ "sku": "Cap-003", "tag": "standard" }
Output:
Custom item: Mug-009 Custom item: SmallMug-010
The helper renders the block once for each element where tag equals "custom". Inside the block, properties of the matching element ({{sku}}, {{tag}}) are accessible directly without a path prefix.
Render the else block when no elements match
{{#filter record.order.lineItems "express" "tag"}}
Found express items
{{else}}
No express items
{{/filter}}
Using the same input as above.
Output: No express items
No elements have tag equal to "express", so the {{else}} block renders.
Usage notes
- Matching is case-sensitive:
"Custom"does not match"custom". - Inside the block, properties of each matching element are accessible directly by name (e.g.,
{{sku}},{{tag}}). - The helper renders once per matching element -- not once for the full array.
- An empty array
[]renders the{{else}}block. A missing, undefined, or non-array value produces no output and does not render{{else}}. -
arrayPropertysupports dot-paths for nested properties:"details.department". - For simple arrays (strings, numbers), omit
arrayPropertyand the helper matches directly against each element's value.
