#isEmpty helper
Renders the main block when the collection is an empty array/object, the parameter is missing/undefined, or the value is null or undefined; otherwise renders the {{else}} block.
Usage
{{#isEmpty collection}}Block if empty{{else}}Block if not{{/isEmpty}}
  • collection (required): array or object to test
Examples
  1. Check if an array or object is empty
    {{#isEmpty record.arr}}Array is empty{{else}}Has items{{/isEmpty}}
    {{#isEmpty record.obj}}Object is empty{{else}}Has keys{{/isEmpty}}
    Input:
      "record": {
        "arr": [],
        "obj": {}
    Output:
    Array is empty
    Object is empty
  2. Non-empty case
    {{#isEmpty record.items}}No items found{{else}}Items available{{/isEmpty}}
    Input:
    { "record": { "items": [1, 2, 3] } }
    Output:
    Items available
  • Works with both arrays and objects.
  • For strings, use the #not helper combined with the value to check for emptiness ({{#not record.value}}).
  • Useful for handling optional fields, conditionally rendering messages, or validating data presence.
  • If the input is not an array or plain object (e.g., boolean/number), #isEmpty treats it as empty and renders the main block.
