The #with block helper sets the context to a nested object for all expressions inside the block. Use it to access multiple fields within a nested object without repeating the parent path in each expression.
Syntax
{{#with object}} {{field1}} {{field2}} {{/with}}
object -- The nested object to use as the context inside the block. Required. All field references inside the block resolve relative to this object.
Examples
Access fields in a nested object
{{#with library}}{{title}} on "{{album}}" by {{artist}}{{/with}}
Input:
"library": {
"album": "The Sound",
"title": "Danube Incident",
"artist": "Lalo Schifrin"
Output: Danube Incident on "The Sound" by Lalo Schifrin
Without #with, each reference would require the full path: {{library.title}}, {{library.album}}, {{library.artist}}.
Mix outer and inner context
The author{{#with author}} {{firstName}} {{lastName}}{{/with}}
Input:
"title": "A Tale of Two Cities",
"author": {
"firstName": "Charles",
"lastName": "Dickens"
Output: The author Charles Dickens
Text and expressions outside the #with block resolve against the root context. Only expressions inside the block use the author object as their context.
Usage notes
- Field references inside a
#withblock resolve relative to the specified object, not the root context. - To reference a root-level field from inside a
#withblock, use the../path prefix:{{../title}}. - If the specified object is missing or undefined, the block is skipped entirely and nothing renders.
#withdoes not iterate over arrays. To loop through array elements, use the #each helper instead.
