The base64Decode helper decodes a base64-encoded string into a specified output format. Use it to handle encoded values in API responses, credentials, or record fields. If no format is specified, the output defaults to UTF-8.
Syntax
{{base64Decode base64String "decodeFormat"}}
base64String -- The base64-encoded string to decode. Required. If the input is malformed, the helper throws an error.
decodeFormat -- The output encoding format. Optional. Defaults to "utf8". Accepted values: "utf8", "ascii", "hex", "base64", "binary", "latin1", "ucs2" / "ucs-2", "utf16le" / "utf-16le".
Examples
Decode a base64 field to a readable string
{{base64Decode record.base64EncodedData "utf8"}}
Input: record.base64EncodedData is "U29tZSBlbmNvZGVkIHZhbHVl"
Output: Some encoded value
Decode a base64 string to hexadecimal
{{base64Decode "SGVsbG8gV29ybGQh" "hex"}}
Output: 48656c6c6f20576f726c6421
This is the hex representation of "Hello World!".
Return raw output with triple braces
{{{base64Decode record.base64EncodedData "utf8"}}}
Use triple braces when downstream systems require the exact decoded string without Celigo's automatic formatting or URI encoding.
Usage notes
- Choose
decodeFormatbased on how the decoded output will be used:"utf8"for readable text,"hex"for raw byte inspection, and so on. - If
decodeFormatis omitted, the output defaults to"utf8". - If
base64Stringis malformed or the format is unsupported, the helper throws an error. Validate inputs when possible. - Use triple braces (
{{{ }}}) for raw output and double braces ({{ }}) when Celigo's default formatting is acceptable.
