camelcase helper
Converts alphanumeric strings (uppercase and lowercase) to camelcase, and removes non-alphanumeric characters - including spaces, dashes, forwardslashes, and underscores. This is useful for creating variable-style keys or formatting labels consistently in integrations. Digits are preserved.
Usage
{{camelcase value}}
  • value (required): input string
Examples
  1. Convert a product type to camelcase
    {{camelcase record.product.type}}
    Input:
      "record": {
        "product": {
          "type": "hand crafted item"
    Output:
    handCraftedItem
  2. Convert from dash-separated string
    {{camelcase record.category}}
    Input:
      "record": {
        "category": "new-arrival-products"
    Output:
    newArrivalProducts
  3. Preserve numbers and remove special characters from in a string
    {{camelcase "version-2_1-final"}} → version21Final
  • Numbers remain unchanged but are preserved in the output (e.g., "order_123_id"order123Id).
  • All caps strings are switched to camelcase ("HELLO&WORLD" → "helloWorld")
  • Use this helper to standardize keys for APIs or when generating identifiers programmatically.
  • Unlike sentence, this helper does not add spaces or adjust casing beyond camelCase rules.
  • Non-alphanumeric characters (except digits) are treated as separators and removed
  • Leading and trailing whitespace is trimmed before conversion
  • Non-string datatype inputs (like numbers or boolean) are converted to strings before processing. Arrays of primitive types (like strings or numbers) are converted into a comma-separated string before processing. If inputs are objects or object arrays, the output will be unusable.
