capitalizeAll helper
Use {{capitalizeAll}} to capitalize the first letter of every word in a string. You can pass a hard-coded string or a field from the record.
Usage
{{capitalizeAll field}}
  • field: The string or field containing text (e.g., "john doe" or record.addressLine1).
Examples
  1. Capitalizing a record field
    {{capitalizeAll record.lastName}}
    If record.lastName is "doe smith", it outputs "Doe Smith".
  2. Capitalizing a literal text
    {{capitalizeAll "the quick brown fox"}}
    Results in "The Quick Brown Fox".
  3. Formatting product titles
    {{capitalizeAll record.productTitle}}
    If record.productTitle is "new release item", you get "New Release Item".
  • Punctuation or special characters can split words differently; verify the output if your text includes unusual symbols.
  • This helper is case-insensitive; it only guarantees the first letter of each word is uppercase. All other letters remain unchanged.
