Removes leading and trailing whitespace and special characters from a string. It is useful when cleaning up input values before using them in a flow.
Remove surrounding characters from labels
{{chop record.label1}} {{chop record.label2}} {{chop record.label3}}Input:
{ "record": { "label1": "_ABC_", "label2": "-ABC-", "label3": " ABC " } }Output:
ABC ABC ABC
Preserve interior punctuation, strip only edges, and avoid HTML escaping with {{{...}}}
{{{chop record.label}}}Input
{ "record": { "label": " Hello*&^World- " } }Output
Hello*&^World
The helper removes spaces, underscores, dashes, and other non-alphanumeric characters at the start or end of the string.
It does not remove characters inside the string body. For example,
"A_B_C"remains unchanged. -
By default, Handlebars HTML-escapes the result. If you need raw output (for strings containing <, >, &, etc.), use {{{…}}}
Non-string inputs (datatypes such as number or boolean) are converted to strings before processing. Arrays of primitive types (like strings or numbers) are converted into a comma-separated string before processing. If inputs are objects or object arrays, the output will be unusable.
