Replace part of a string in your flow data with a new value, using a regular-expression pattern to identify what should change.
See also Regular expressions (regex) .
{{regexReplace field replacement regex}}
field – The text field or variable to modify (e.g.,
record.order.notes). -
replacement – The value that should replace every substring matching regex.
regex – Regular-expression pattern that identifies the text to replace.
Redacting credit-card digits in free-form notes
{{regexReplace record.notes "#### #### #### ####" "[0-9]{4} ?[0-9]{4} ?[0-9]{4} ?[0-9]{4}" "g"}}If
record.notesis"Payment with 4111 1111 1111 1111 approved"→Payment with #### #### #### #### approved -
Normalizing SKU format (remove spaces & dashes)
{{regexReplace record.item.sku "" "[ -]" "g"}}"ABC-123 45"→ABC12345 -
Converting CRLF line-endings to LF and returning raw output
{{{regexReplace record.description "\n" "\r\n" "g"}}}Triple braces give the cleaned text exactly as produced, without Celigo’s automatic quoting or encoding.
Patterns are JavaScript-style regular expressions—escape special characters (
\.for a literal dot,\\for a backslash, etc.). -
If the field might be empty or missing, combine this helper with a conditional or default to avoid null results.
Use triple braces (
{{{ }}}) when you must embed the modified text without Celigo’s automatic formatting (e.g., inside a JSON body that you are building manually).Use theregexReplacehelper to search a string for a specified pattern and replace matches with a chosen value. This is useful for cleaning up data, removing unwanted characters, or transforming fields into a new format before exporting them.
