The snakecase helper converts a string to snake_case format by replacing spaces, dashes, and other non-word characters with underscores and lowercasing the result. Use it to generate consistent identifiers, database field names, or API parameters that follow underscore naming conventions.
Syntax
{{snakecase value}}
value -- The string to convert. Required. Non-string inputs (numbers, booleans) are converted to strings before processing. Arrays of primitive values are converted to a comma-separated string. Objects and object arrays produce unusable output.
Examples
Convert a mixed-separator string
{{snakecase record.product.label}}
Input:
{ "record": { "product": { "label": "a-b-c d_e" } } }
Output: a_b_c_d_e
Existing hyphens, spaces, and underscores are all normalized to a single _.
Convert a space-separated string
{{snakecase record.category}}
Input:
{ "record": { "category": "New Product Launch 2025" } }
Output: new_product_launch_2025
Split at camelCase boundaries
{{snakecase record.userAction}}
Input:
{ "record": { "userAction": "getUserProfile" } }
Output: get_user_profile
The helper inserts underscores at camelCase and PascalCase word boundaries and lowercases the result.
Usage notes
- All word separators (spaces, dashes, and other non-word characters) are normalized to a single
_. - Multiple consecutive separators are collapsed into a single underscore.
- The output is always lowercased.
- Underscores are inserted at camelCase and PascalCase boundaries.
- Digits are preserved. Underscores are not inserted between letters and adjacent digits unless a separator already exists.
- Do not pass objects or object arrays -- the output will be unusable.
