Install the Employee Onboarding and Offboarding business process automation for Paylocity
Before you install
You need to have access to Paylocity API and relevant application APIs. Also, ensure to have the right user permissions sets, scopes added at Paylocity, and other applications.
Create your Celigo iPaaS account
Install Employee Onboarding and Offboarding business process automation for Paylocity
Step 1: Install the template from the Marketplace
  1. Login to integrator.io with admin credentials.
  2. In the left menu, select Marketplace.
  3. On the Marketplace page, select Paylocity.
  4. Find the Employee Onboarding and Offboarding for Paylocity template and select Preview.
  5. Select Install now.
Step 2: Configure Paylocity connection
  1. Select Configure.
  2. If you have already set up a connection, select it from the list. Otherwise, select Set up a new connection and provide your account credentials, see Set up a connection for Paylocity API
  3. Select Save & close to test the connection and return to the template installation.
Step 3: Choose and configure destination application(s)
The destination applications which are supported by this template are as follows:
  • Okta
  • NetSuite
  • Salesforce
  • SAP Concur Expense
  • Microsoft Entra ID
  • Litmos
  1. Select Configure and choose the destination application among the 6 applications displayed under the drop-down.
  2. Select Configure and set up a connection to your destination application(s).
  3. If you have already set up a connection to the application(s), select it from the list. Otherwise, select Set up a new connection and provide your account credentials.
References to set up a new connection for each application:
Get started with the template
Now that you’ve installed this template in your integrator.io account, understand how to configure and run your flows:
To understand template management, see Delete or restore a quickstart integration template.
