The jsonStringify helper converts a value into JSON text. Use it when a template needs the JSON for an object or array you already have in context, such as a child object taken from a parsed payload.
Note: Always use triple braces ({{{ }}}). Double braces cause Celigo to encode quotes in the JSON, which can make the string invalid for the system that receives it.
Syntax
{{{jsonStringify value}}}
value -- The value to convert. Required. Objects and arrays become compact JSON text, with no extra spaces. A string is returned with its JSON quotes. A number or boolean is returned as its literal JSON text.
Examples
Stringify a child object
{{#with (jsonParse record.payload)}}{{{jsonStringify event}}}{{/with}}
Input:
"record": {
"payload": "{\"event\":{\"type\":\"create\",\"source\":\"api\"},\"id\":[123,456,789],\"status\":\"success\"}"
Output:
{"type":"create","source":"api"}
#with and jsonParse open the stringified payload. jsonStringify writes the event object back out as JSON text.
Stringify an array
{{{jsonStringify record.items}}}
Input:
"record": {
"items": [
{ "sku": "ITEM001", "quantity": 2 },
{ "sku": "ITEM002", "quantity": 1 }
Output:
[{"sku":"ITEM001","quantity":2},{"sku":"ITEM002","quantity":1}]
Stringify a string
{{{jsonStringify record.email}}}
Input: record.email is "jane.doe@example.com"
Output: "jane.doe@example.com"
The quotes are part of the JSON text. Use the jsonEncode helper when the destination needs the same characters with no surrounding quotes.
Usage notes
- Always use triple braces (
{{{ }}}). Double braces encode the quotes in the result. - The JSON is compact. Objects and arrays are not indented, and there is no space after
:or,. - A string result includes JSON quotes. A number such as
89.99returns89.99, and a boolean returnstrueorfalse. -
jsonParseturns JSON text into an object or array.jsonStringifyturns an object or array back into JSON text. -
jsonSerialize helper is the other helper that writes a JSON string. jsonEncode helper does not serialize objects. An object passed to
jsonEncodereturns[object Object].
