Monitor flows in an integration
An integration's Flows tab lists every flow registered to that integration — and only those — with each flow's status, last run, and the controls to map, schedule, run, and turn it on or off without opening it. It's the day-to-day view of an integration's flows. This article is the reference for what each column shows and what each action does; building and running flows are covered in the articles it links to.
Open the Flows tab
  1. Go to Home home-icon.png, and then open the integration.
  2. Select Flows. It's the tab that opens by default.
Use the search box to find a flow by name, and select a column heading to sort. If the integration uses flow groups, select a group under Flow groups on the left to show only its flows. Last updated and Last run follow the date and time format in your account profile; see Change your email, time zone, and profile settings.
To add a flow, select Create and then Flow, Multi-instance flow, or Data loader flow; see Create a flow. Create flow group in the same menu adds a group; see Organize flows and APIs into groups.
Columns and controls
Column What it shows
Name/Description The flow's name and description. Select the name to open the flow in Flow builder.
Errors Success when the flow has no open errors, or the count of open errors. Select it to open the flow's errors; see Errors page.
Last updated When the flow was last changed.
Last run When the flow last ran. Empty for a flow that has never run. For a multi-instance base flow, the most recent run of any of its instances. For every run, open the flow's Run history tab; see View a flow's run history.
Mapping mapping-icon.png Opens the flow's import mappings — Add mapping when the flow has none yet, Edit mapping once it does. A flow with several import steps asks which step's mapping to open. See Mapper 2.0.
Schedule Opens the flow's schedule; see Schedule a flow. A flow that runs in real time — from a listener or a topic subscription — shows Realtime instead. The schedule can't be set until every step in the flow is configured.
Run Runs the flow now, regardless of its schedule; see Run a flow. Not available for a flow that only listens to a topic.
Enabled enable-flow.png Turns the flow on or off. You can turn one flow off without stopping the rest of the integration.
Actions elipses-button.png The actions in the next table.
Actions
Action What it does
Edit flow Opens the flow in Flow builder.
View audit log Shows the audit log for this flow. The integration's own audit log is on its Audit log tab.
Used by Shows where the flow and its resources are used. Check it before you delete a flow that might share resources with another.
Clone flow Copies the flow into the same or another integration or environment; see Clone a flow.
Download flow Saves the flow as a ZIP file; see Download a flow.
Move flow Moves the flow to another integration; see Move a flow to another integration.
Delete flow Deletes the flow and sends it to the Recycle bin; see Delete a flow.
