Clone a flow to get a copy you can change without touching the original — to test a variation, start a similar flow for another application, or put a copy in a different integration or environment. The clone carries the flow's steps and their configuration; connections, the schedule, and run history don't come with it. This article explains what a clone contains and how to make one. To copy a whole integration, see Clone integrations and resources.
Prerequisites: You must have Manage permissions for the integration; see Manage user roles & permissions to an account. Flows shared with you from another account can't be cloned.
What a clone contains
| Carried over | Not carried over |
| Exports, imports, lookups, and the scripts the flow references | Connection credentials — the clone reuses the original connections in the same environment, and asks you to choose connections in a different environment |
| Mappings, transformations, filters, and hooks | The schedule and next run time |
| Branching | Run history and errors |
| The flow group, when the clone stays in the same integration |
A flow that uses a lookup cache keeps the reference when the clone is in the same environment. In another environment, point the clone at a cache there or clone the cache; see Lookup caches overview.
Clone a flow
- Go to Home
, open the integration, and then select Flows.
- Select the flow's Actions
> Clone flow.
- Enter the details for the flow, and then select Clone flow.
- For each connection the clone needs, accept the preselected connection (same environment) or select or create one (different environment). For environments, see Create and manage multiple environments.
The clone opens in Flow builder, turned off and without a schedule. Set a schedule and turn it on when it's ready; see Schedule a flow and Run a flow.
