Manage integrations on the Home page
The Home page lists every integration in the current environment and is where you create, find, organize, and act on them. You can show integrations as tiles for a quick picture of their status or as a list you can sort, filter, and pin, and from either view you can clone, download, or delete a custom integration without opening it. This article describes both views, the status each shows, and the actions available from the page.
Switch between tile view and list view
  1. Go to Home home-icon.png.
  2. At the top right, select Tile view tile-view-icon.png or List view list-view-icon.png.
Tile view is the default. Use it when you have a few integrations and want their status at a glance. Use list view when you have many integrations or want to sort, filter, or pin them — those three features are available only in list view. You can search in both views.
What a tile shows
Each tile shows the integration's name, its status (Success or a count of open errors), a red offline-connections indicator when one or more of its connections is down, the number of flows it contains, and Actions elipses-button.png at the top right. When you point to a tile, a drag handle appears at its top left so you can rearrange tiles; see Rearrange tiles.
What the list shows
Column What it shows
Name/Description The integration's name. Select the info icon next to it to read the description. If you have more than one instance of an integration app, the instance's tag is shown with the name.
Applications The logo or name of every application the integration connects to, including universal connectors. An application appears once even if the integration has several connections to it. Not shown for legacy SuiteScript integrations.
Status The integration's state. See Status values.
Last open error When the most recent unresolved error occurred.
Last updated When the integration or any of its resources last changed.
Type Custom or Integration app, with the number of flows.
Actions elipses-button.png The actions available for the integration. See Actions available from the Home page.
Status values
Status Meaning
Success (green) The integration is installed and none of its flows has an open error.
<count> errors (red) The number of open errors across the integration's flows.
<count> connections down (red) The number of the integration's connections that are offline. In list view this appears on a second line under the status.
Continue set up (yellow) An integration app, or a custom integration installed from a ZIP file, whose setup isn't finished.
Continue uninstall (yellow) An integration app, or a custom integration installed from a ZIP file, whose uninstall isn't finished.
A warning icon on an integration means one of its flows uses an AI model that needs attention. Select the icon to open the Model attention panel and review the affected models, their retirement dates, and the recommended replacements; see Understand AI model lifecycle labels.
Search for an integration
  2. In Search integrations & flows, enter the integration's name or a word from its name or description.
Sort integrations
Sorting is available in list view only.
  1. Go to Home home-icon.png, and then select List view list-view-icon.png.
  2. Select a column heading to sort by it; select it again to reverse the order. You can sort by Name/Description, Status, Last open error, Last updated, and Type.
Sorting by Status orders integrations by their number of errors, from highest to lowest, where errors are the sum of flow errors and offline connections; integrations with errors come first, then Success, then Continue set up and Continue uninstall. Sorting by Type puts custom integrations first, ordered by their number of flows, and then integration apps. A pinned integration moves with the sort order instead of staying at the top.
Filter integrations by application
Filtering is available in list view only.
  2. In the Applications column heading, select Filter filter-icon.png.
  3. Select the applications to include, and then select Apply.
Pin an integration
Pinning keeps the integrations you use most at the top of the list, so you don't have to search or scroll for them. Pinning is available in list view only.
  2. Select the integration's Actions elipses-button.png > Pin integration.
The integration moves to the top of the list with a pin icon. To unpin it, select Unpin integration in the same menu.
Rearrange tiles
In tile view, you can drag integrations into the order you want, for example to keep your highest-priority integrations first.
  1. Go to Home home-icon.png, and then select Tile view tile-view-icon.png.
  2. Point to a tile, and then drag it by the handle at its top left.
Select Actions elipses-button.png — at the top right of a tile, or in the Actions column of the list — to see the actions for the integration's type.
Integration type Action What it does
Custom integration Clone integration Creates a duplicate you can change without affecting the original. See Clone an integration.
Custom integration Download integration Saves the integration as a ZIP file you can share with other users. See Download or install an integration ZIP file.
Custom integration Delete integration Removes the integration and its flows. See Delete or restore an integration.
Integration app Clone integration Creates a duplicate of the integration app. Cloning is supported only by some integration apps — ask Ora whether yours is one of them. If it isn't, check whether the template utility is available; see Clone integration app flows with the template utility.
Integration app Renew subscription Appears 30 days before the subscription expires. See Manage your Integration App subscription.
Integration app Reactivate subscription Appears only after you renew the subscription. See Manage your Integration App subscription.
Integration app Uninstall integration Removes the integration app. See Uninstall your integration app.
Both Pin integration / Unpin integration List view only. See Pin an integration.
To create an integration, select Create at the top right of the page; see Create an integration. To install an integration from a ZIP file, select Upload; see Download or install an integration ZIP file.
