The Dashboard shows every flow run in progress and every run that completed during your data retention period — 30 days by default — with each run's record counts and errors. Open it from the left navigation to watch all the integrations in your account at once, or from an integration's Dashboard tab to watch that integration alone; both views have the same tabs and columns. This article explains what the Running flows and Completed flows tabs show and how to filter them, cancel a run, and get to a flow's errors and run history from here.
Open the Dashboard
- For every integration in the account, go to Dashboard
- For one integration, go to Home
, open the integration, and then select Dashboard.
If your account has a B2B subscription, the Dashboard also has an EDI activity tab; see Getting started with EDI-B2B Manager.
Filter the Dashboard
Both tabs offer:
- Search flows, instances — Find a flow by name.
- Application — Show only flows that use the application you choose.
Filter
in a column heading — Limit the list to specific integrations, flows, statuses, or durations.
- Per — Set how many flows to show per page.
- Refresh — Reload the list.
On the Completed flows tab, Date range limits the list to runs that completed in the period you choose: Today, Last 24 hours (the default), Last 36 hours, Last 7 days, Last 15 days, Last 30 days, or Custom range for your own start and end dates. Select Apply after choosing.
Running flows
The Running flows tab lists every flow that's running or waiting to run.
A flow that needs a connection another flow is still using waits, and its status shows In queue until the connection is free; while the flow's steps run, the status shows In progress. Select the status to open Queued jobs, which lists everything running or waiting and lets you cancel it.
| Column | What it shows |
| Integration | The integration that contains the flow. Select it to open the integration. Shown in the account-wide view only. |
| Flow | The flow's name. Select it to open the flow. |
| Status | In queue or In progress. |
| Started | When this run started, in your account's date and time format; see Change your email, time zone, and profile settings. |
| Duration | How long the run has been going. |
| Success | Records processed successfully so far. |
| Ignored | Records the flow skipped so far, for example because a filter excluded them. |
| Errors | Errors so far. Select the count to see which flow step produced them and open the errors; see Errors page. |
| Auto-resolved | Errors that integrator.io resolved on its own because a later record with the same trace key succeeded; see Set a custom trace key. |
| Pages | Pages of records processed so far. |
Actions |
Cancel stops the run, whether it's in progress or in queue. |
Completed flows
The Completed flows tab lists every run that finished or was canceled within the Date range, with the errors it produced.
| Flow/Instance | The flow's name, or the instance's name for a multi-instance flow. Select it to open the flow. |
| Open errors | Unresolved errors in the flow. Select the count to see which flow step produced them and open the errors; see Errors page. |
| Last open error | When the most recent error occurred. The time doesn't change when the error is resolved. |
| Last run completed | When the flow's latest run finished. |
| Runs | How many times the flow ran in the date range. Select the count to open the flow's Run history; see View a flow's run history. |
| Average run time | The average length of the flow's runs in the date range. |
| Success | Records processed successfully in the date range. |
| Ignored | Records the flow skipped in the date range. |
| Errors | Errors in the date range. |
| Auto-resolved | Errors that integrator.io resolved on its own because a later record with the same trace key succeeded. |
| User-resolved | Errors a user marked as resolved. |
| Pages | Pages of records processed in the date range. |
Select a flow's name to expand it and see the same counts for each of its steps.
Each error in the list you reach from Open errors carries a Message, a Code, its Source step, a Classification, and a Timestamp. To retry or resolve errors, see Errors page; for what each classification means, see Error classifications; to follow a retry, see Understand the Errors page.
