When an integration holds many flows or APIs, you can sort them into named groups so that each group acts like a folder on the Flows or APIs tab: the groups are listed under Flow groups on the left, and selecting one shows only the flows or APIs assigned to it, with a status dot for each group. Groups are purely a way to organize what you see — assigning a flow to a group doesn't change its schedule or any other setting that decides when it runs, and the order of groups doesn't decide the order flows run in. This article shows you how to create, reorder, edit, and delete groups in an integration you have Manage access to.
Keep in mind:
- Flows and APIs you haven't assigned appear under a system group named Unassigned.
- A flow or API can belong to only one group at a time. If you assign a flow to group A and later include it in group B, it moves to group B.
- When you clone an integration, its groups and group assignments are cloned with it; see Clone an integration.
- To control when flows run, or make them run one after another, set their schedules; see Schedule or run flows.
Create a group
- Go to Home
, and then open the integration.
- On the Flows tab, select Create > Create flow group; on the APIs tab, select Create > Create API group.
- Enter a Name that describes the business process the flows or APIs belong to, such as Fulfillment or Billing.
- Select each flow or API to include in the group.
- Select Save & close.
Repeat for each group you want.
Reorder groups
- Go to Home
- On the Flows or APIs tab, point to a group name under Flow groups on the left.
- Drag the group by the handle that appears.
Edit a group
You can rename a group or change which flows or APIs it contains.
- Go to Home
- On the Flows or APIs tab, select the group.
- Select Actions
> Edit flow group or Edit API group.
- Change the name or the assignments.
Delete a group
Deleting a group moves its flows or APIs to Unassigned. Nothing else is deleted.
- Go to Home
- Select Actions
> Delete flow group or Delete API group.
