The Connections tab lists every connection registered to an integration — the stored credentials and access details that its flows use to reach each application — along with whether each connection is online and how many records are waiting in its queue. All working flows need online connections, so this tab is the first place to look when an integration shows connections down. This article describes the tab's columns and actions and shows you how to add a connection to the integration, either by creating one or by registering one that already exists in your account. For what a connection is and how to set one up for a particular application, see Create a connection to an application.
A red dot on the Connections tab means at least one of the integration's connections is offline.
Columns
| Column | What it shows |
| Name | The connection's name. Give each connection a name that says what it's for — for example the application, the account (production or sandbox), and the integration it serves — because you may have several connections to the same application. Select the name to open the connection. |
| Status | Online or Offline. A connection can go offline because its credentials are invalid, the application's API has a problem, or there's another connectivity error. Open an offline connection, review the errors, and re-enter its details. |
| Application | The application the connection reaches. |
| API | The API endpoint the connection uses. Use it to tell apart connections to different accounts of the same application. |
| Last updated | When the connection was last changed, in your account's date and time format; see Change your email, time zone, and profile settings. |
| Queue size | The number of records waiting in the connection's queue. If the number keeps growing, data is arriving faster than the destination application can accept it; consider adding a connection to the application or raising the connection's concurrency. See Fine-tune integrator․io for optimal performance and data throughput. |
Actions |
The actions in the next table. |
When you save a connection, its password, API key, token, or other secret is stored but never shown again. If you edit the connection, enter the secret again.
Actions
| Action | What it does |
| Edit | Opens the connection so you can change its details. |
| Debug | Opens the connection debugger, which records every request and response between integrator.io and the application for a period you choose. The connection debugger isn't available for DynamoDB, MongoDB, or wrapper connections; for those, use a test-mode flow run, mock data, or the connected system's own logs. |
| View audit log | Shows the connection's audit log. |
| Used by | Lists every export, import, flow, and integration that uses the connection. |
| Deregister | Removes the connection from this integration. The connection itself isn't deleted. |
Create a connection from the integration
- Go to Home
, and then open the integration.
- Select Connections.
- Select Create connection, and then choose the Application.
- Enter the connection's details and test it; see Create a connection to an application and the application's own article in Connector solutions.
The new connection is registered to the integration.
Register an existing connection
Registering a connection to an integration makes it available to every flow in the integration and lists it on this tab, so you can find every export and import that uses it.
- Go to Home
- Select Register existing.
- In Existing connections, select each connection to register, and then select Register.
