Set up email notifications for flow errors or offline connections
You can quickly set up email notifications for flow errors or offline connections from the Alerts tab of an integration. You can also set up alerts for long run time flows from this tab, which is covered in a separate article, Set alerts for long-running flows.
The Alerts tab was previously named Notifications. To learn more about how these notifications work, see How integrator.io handles email notification of errors.
Tip: If you are an  admin, you can set up notifications for other users from the Users tab of each integration.
To set up your notifications for flow errors or offline connections:
  1. From the home page, select the integration that contains the flows or connections for which you want to configure notification or alerts.
  2. In the Integration page, select More and then Alerts.
  3. Based on your requirements, select the flows or connections or both for which you want to receive notifications.
  4. If you want to be notified of flow errors, under Notify me of flow errors, select All flows or specific flows.
    Note: If your integration uses flow groups, the name of the group appears to the right of each flow name.
  5. If you want to be notified of offline connections, under Notify me when connection goes offline, select any specific connections.
  6. Click Save.
