Set up an OAuth 1.0 HTTP connection
The OAuth 1.0 authentication standard enables applications to grant access to their protected resources without disclosing their credentials to the consumer. OAuth 1.0 creates a generic methodology for API authentication. It uses tokens generated by the service provider instead of the user’s credentials for requests to protected resources, and it has become required or preferred by providers like Magento and Twitter.
You can select this option to connect to any OAuth 1.0-compliant app that does not have a prebuilt integrator.io connection, or you can build your own OAuth 1.0 connection for a supported app and exercise finer control over each setting, as described below.
  • OAuth 1.0 is a three-stage workflow, where the client first gets temporary credentials, performs authorization, and exchanges the temporary credentials for permanent long-lived tokens. This connector type assumes that you have already completed these steps and obtained the long-lived token and secret before setting up an OAuth 1.0 connection using endpoints. However, in the near future, Celigo will launch an upgraded OAuth 1.0 connector with the ability to retrieve the credentials for you.
  • OAuth1.0 requires signed requests with complicated signature methods. While establishing the OAuth1.0 connection, integrator.io will sign the request using the signature method that you choose below.
A. Set up an HTTP connection
  • From the Resources menu, select Connections. Then, click+ Create connection at the top right.
  • While working in a new or existing integration , you can add an application to a flow simply by clicking Add source or Add destination/lookup. From the Application list, under Universal connectors, select HTTP.
  • After the HTTP Application is added, click the Connection setting’s + button to proceed.
Name (required): Enter a clear and distinguishable name. Throughout integrator.io imports and exports, you will have the option to choose this new connection. A unique identifier will prove helpful later when selecting it from a list of the connections in your account.
  • Cloud to connect to a publicly accessible server application.
  • On-premise to connect to a server that is publicly inaccessible and has an integrator.io agent installed on it.
C. Edit OAuth 1.0 settings
Continuing in the Create connection panel, select OAuth 1.0 for the Auth type. The settings then become specific to OAuth 1.0.
As with all universal API connections, the parameters are unique to the vendor’s conventions. Before proceeding, review the developer documentation and your account settings.
Signature method (required): Select the required method to sign the API call:
  • HMAC-SHA1
  • HMAC-SHA256
  • HMAC-SHA512
  • RSA-SHA1
  • RSA-SHA256
  • RSA-SHA512
  • PLAINTEXT
Consumer key (required): Enter your consumer key. The consumer uses this value to identify itself to the service provider. This is enabled and required for all the Signature methods.
Consumer secret (required): Enter your consumer secret. The consumer uses this password to establish ownership of the consumer key. This is enabled and required when Signature method is HMAC-SHA1, HMAC-SHA256, HMAC-SHA512, or PLAINTEXT. Multiple layers of protection, including AES 256 encryption, are in place to keep your secret safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Access token (required): Enter the access token. The consumer uses this token to gain access to the protected resources on user's behalf. This is enabled and required for all the Signature methods. Multiple layers of protection, including AES 256 encryption, are in place to keep your token safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Token secret (required): Enter the token secret. The consumer uses this secret to establish ownership of a provided token. This is enabled and required when Signature method is HMAC-SHA1, HMAC-SHA256, HMAC-SHA512, or PLAINTEXT. Multiple layers of protection, including AES 256 encryption, are in place to keep your secret safe. When editing this connection, you must re-enter this value each time; it is stored only when the connection is saved and never displayed as text.
Consumer private key (required): Enter the consumer private RSA key. This key is used to sign the API call request. This is enabled and required when Signature method is RSA-SHA1, RSA-SHA256, or RSA-SHA512
Realm (optional): Enter the realm value. For more information, see your application's API documentation.
Non-standard API response patterns
This section is collapsed by default since all of its settings are optional.
D. Edit common HTTP settings
Additional HTTP settings are found in the other sections in the Create connection panel (optional sections are collapsed by default):
  • Application details(contains the required settings Base URI and Media type)
  • Non-standard API rate limiter
  • How to test this connection?
  • Advanced
E. Save and test the connection
  • Save & close – click to test and save the connection and exit the Create connection panel
