Set up a JWT bearer auth HTTP connection
Use JWT (JSON Web Token) as a secure digital pass to improve your app’s identity for OAuth specification. You can generate secure JWT tokens by signing in using signature methods such as RSA-SHA and HMAC-SHA. Then, you can utilize these JWT tokens or access tokens to invoke your APIs securely.
A. Set up an HTTP connection
You can also create a new connection while working on an export , import, or flow. In the Create export or Create source and Create import or Create destination page, select the application you are connecting to and enter the required settings. Next to the Connection setting, click the plus sign (+) and provide details in the Create connection page.
  • From the navigation menu, select Resources → Connections.
  • In the ,Connections page, click + Create connection at the top right.
  • In the Create connection page, for Application, start entering HTTP in the search box to quickly find and select the HTTP connection listed under the Universal connectors group.
Name (required): Enter a clear and distinguishable name. Throughout integrator.io imports and exports, you will have the option to choose this new connection. A unique identifier will prove helpful later when selecting it from a list of the connections in your account.
C. Edit JWT bearer settings
Continuing in the Create connection panel, select JWT bearer for the Auth type. The settings then become specific to the JWT bearer authentication type.
As with all universal API connections, the parameters are unique to the vendor’s conventions. Before proceeding, review the developer documentation and your account settings.
Signature method (required): Select the required method to sign the API call. For HMAC signature options, the secret key appears. For all other options, a private key is required.
Payload (required): The JSON object contains the message sent to the application. This is used along with the secret key to ensure no alteration to the message along the way.
JWT headers (optional): The JWT header is a JSON object that typically consists of two properties:
  • alg (Algorithm): Specifies the algorithm used to sign the token. It can be HMAC SHA256, RSA SHA256, or others, depending on the chosen cryptographic algorithm.
  • typ (Type): Indicates the token type, typically set to "JWT" for JSON Web Tokens.
Secret (required, HMAC only): Enter the secret key to sign and verify the JWT bearer.
Secret Base64 encoded: Check this box if the secret key is base64 encoded. The value will be automatically decoded to generate the signature. This option applies to HMAC-based signatures (HMAC-SHA256, HMAC-SHA384, and HMAC-SHA512).
Private key (required, non-HMAC only): Copy the private key from the portal you want to use to authenticate the connection. Before you add it to integrator.io, you must replace all newline characters (\n) throughout the private key. The private key must be in PEM format. You can convert PFX certificates or convert from a PPK file.
Paste your private key
  • Paste the private key into a text editor.
  • Find \n.
  • Delete the \n characters and press Enter or Return. Repeat this for each instance of \n.
  • Ensure -----BEGIN PRIVATE KEY----- appears before the key, and -----END PRIVATE KEY----- appears after the key.
  • Copy and paste the reformatted private key (including the begin and end declarations) into integrator.io.
D. Edit common HTTP settings
Additional HTTP settings are found in the other sections in the Create connection panel (optional sections are collapsed by default):
  • Application details(contains the required settings Base URI and Media type)
  • Non-standard API rate limiter
  • How to test this connection?
  • Advanced
E. Save and test the connection
  • Save & close – click to test and save the connection and exit the Create connection panel
