Set up a cookie-based HTTP connection
Some companies put their documentation on third-party sites. If you can’t find the guide on their website, you can also try a web search.
Some APIs authorize calls and maintain session information by responding to a cookie request, which is sent back in a set-cookie response header. Cookie authentication is vulnerable to cross-site request forgery (CSRF) attacks and should be used with other security measures, such as CSRF tokens.
A. Set up an HTTP connection
  • Select Connections from the Resources menu.
  • Next, click + Create connection at the top right. In the resulting Create source panel, select HTTP from the Application list, under the Universal connectors group.
  • While working in a new or existing integration , you can add an application to a flow simply by clicking Add source or Add destination/lookup. From the Application list, under Universal connectors, select HTTP.
image idm45505574267296
  • After the HTTP Application is added, click the Connection setting’s + button to proceed.
C. Edit cookie auth settings
Continuing in the Create connection pane, select Cookie for the Authentication type. The settings then become specific to cookie-based connections:
HTTP method (required): Select GET or POST, depending on the API requirements for making a request for the cookie.
HTTP request body (enabled and required when HTTP method is POST): Enter the body that will be posted to the URI endpoint. Click the handlebars button (handlebars_editor.svg) to open the Advanced field editor and create or edit a template. You may reference any fields in your connection or flow's data within handlebars {{placeholders}}.
Absolute URL (required): Enter the endpoint that integrator.io will use to make the cookie authorization request. Click the handlebars button (handlebars_editor.svg) to open the Advanced field editor and create or edit a template. You may reference any fields in your connection or flow's data inside handlebars {{placeholders}}.
Override HTTP status code for success (optional): If the application returns any success status code other than 200, enter the expected value.
D. Edit common HTTP settings
  • Application details (contains the required settings Base URI and Media type)
  • Nonstandard API rate limiter
  • How to test this connection?
  • Advanced
E. Save, test, and authorize
