You can build integrations with apps that use the HTTP application connector, even if the specific app connector is not already provided by integrator.io.
Before creating the connection, review your app’s API guide. It will provide the information you need, such as the kind of authentication that the app requires and its URI. Every app puts its documentation – guides and reference material – in different places. You can often find it by searching for “API guide” or “API documentation” on the company’s website.
Some companies put their documentation on third-party sites. If you can’t find the guide on their website, you can also try a web search.
Although the HTTP/1.0 protocol includes a basic authentication scheme, this is not considered to be a secure method of user authentication, as the username and password are passed over the network in an unencrypted form. The digest authentication type, on the other hand, does not send the password in plain text, thus avoiding the most serious flaw of basic authentication. However, it does not meet all security needs and does not encrypt message content.
Select Connections from the Resources menu.
Next, click + Create connection at the top right. In the resulting Create source panel, select HTTP from the Application list, under the Universal connectors group.
While working in a new or existing integration , you can add an application to a flow simply by clicking Add source or Add destination/lookup. From the Application list, under Universal connectors, select HTTP.
After the HTTP Application is added, click the Connection setting’s + button to proceed.
Cloud to connect to a publicly accessible server application
On-premise to connect to a server that is publicly inaccessible and has integrator.io agent installed on it
Continuing in the Create connection panel, select Digest for the Auth type. At a minimum, you must provide your username and password to establish a connection with digest authentication:
Username (required): Enter the digest authentication username for the server. The username and password information will be used in generating the digested string and added in the Authorization
header during API calls.
Password (required): Enter the password for this account. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this value again; it is stored only when the connection is saved and never displayed as text.
Path to auth error field in HTTP response body (optional): If the API returns a field that contains auth errors in the HTTP response body, enter the JSON path to that field. For example, when an API returns the field errorMessage
with the value Auth failed
, then enter errorMessage
as the path.
Application details(contains the required settings Base URI and Media type)
Nonstandard API rate limiter
How to test this connection?
Advanced
Save – click this button to test the connection, commit the new connection so that it will be available to all integrations for your account
Save & close – click to test and save the connection and exit the Create connection pane
Close – click to exit without saving any new changes
Test connection – click this button to verify that your new connection is free of errors
