Set up permissions for non-administrators roles in NetSuite
Each non-administrator will be able to only access the NetSuite record types that their role permits. Not having adequate role permissions could lead to unwanted errors when executing the data flows. In order for the user to set up, run, and maintain integrations and integration apps with a non-administrator role, you need to provide controlled access using the Permissions option in NetSuite.
To set up controlled access permissions in NetSuite, select Setup > Users/Roles > Manage Roles. The Manage Roles page is displayed. Find the role for which you need to customize the permissions and click Customize. The Role page is displayed.
Install permissions
In the Permissions tab, ensure that the following permissions are enabled for the user:
Section | Permission | Level |
Setup | WebServices | Full |
Setup | SuiteScript | Full |
Setup | SuiteBundler | Full |
Operation permissions
Setup | SuiteScript | View |
Setup | SuiteScript Scheduling | Full |
Setup | Custom Record Types | View |
Setup |
Custom Lists Note: Permissions needed to view the Match Method pie chart on the CAM Dashboard |
Full Access |
Lists | Accounts | View |
Lists | Custom Record Entries | Edit |
Lists | Customers | Edit |
Lists | Documents and Files | Full |
Lists | Subsidiaries | View |
Lists | Perform Search | Full |
Transactions | Make Journal Entry | Create |
Transactions | Find Transaction | View |
Transactions | Customer Deposits | Create |
Transactions | Customer Payment | Create |
Transactions | Credit Memo | View(Only if Credit Memo feature is needed) |
Transactions | Invoice | Full |
