Shopify is an e-commerce platform that allows users to set up an online store and sell their products. It helps you manage your orders from inventory to point of sale to shipping and returns.
Only users with an existing legacy custom app and valid API credentials can configure a connection using Basic authentication as described below. From January 1, 2026, Shopify no longer allows the creation of new legacy custom apps. Existing legacy apps can still generate static API credentials (such as an API key and password or an Admin API access token) for direct API access. However, custom apps created through the Shopify developer dashboard do not provide static credentials and do not support Basic authentication. Apps created in the developer dashboard must use Shopify’s supported OAuth or token acquisition flows to authenticate API requests.
It is recommended to use the 2025-04 API version.
Selecting another connection from the drop-down list changes the form. The concurrency level will be hidden, set to the same shared value as the other connection’s.
You can view the admin API access token on this page only once. Hence, it is recommended to copy and save your token in a secure place. Consider this token as a password and share it only with the developers you trust.
API type * |
Choose your Shopify account API type:
API version |
Select your Shopify account API version. For example, 2026-01. For more information, see REST admin API reference. |
Store name * |
Enter your Shopify store name. For example, if your URL is |
Auth type * |
Select Basic as the authentication type for this connection. |
Username * |
Enter your Shopify app API key. |
Password * |
Enter the Admin API access token (not your Shopify account password). Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this value again; it is stored only for a saved connection. |
This connector documentation describes only the settings shown for the Simple view.
For the corresponding:
HTTP settings, see Set up a basic auth HTTP connection documentation.
GraphQL settings, see Set up a connection to a GraphQL endpoint documentation.
Sign in to your Shopify account.
Navigate to Apps > App and sales channel settings > Apps and sales channels > Develop apps.
Select the installed app and navigate to API credentials.
Copy Admin API Access token (Password).
From the API key and secret key section, copy the API key (Username).
