Set up a WSSE-based HTTP connection
Tip: Some companies put their documentation on third-party sites. If you can’t find the guide on their website, you can also try a web search.
HTTP connections can have an authentication type of WSSE (Web Services Security Environment), which is part of the web service specifications. This authentication has to be used where the connecting application expects crypto hash generated out of the username and the password and this value is sent over as part of the header. The default name of the header is X-WSSE, which is customizable.You can use this for connectors that authorize API calls based on WSSE tokens sent in the request header.
A. Set up an HTTP connection
  • Select Connections from the Resources menu.
  • Next, click + Create connection at the top right. In the resulting Create source panel, select HTTP from the Application list, under the Universal connectors group.
  • While working in a new or existing integration , you can add an application to a flow simply by clicking Add source or Add destination/lookup. From the Application list, under Universal connectors, select HTTP.
image idm45505574577824
  • After the HTTP Application is added, click the Connection setting’s + button to proceed.
C. Edit WSSE auth settings
Continuing in the Create connection panel, select WSSE for the Auth type. The settings then become specific to WSSE:
Username (required): Enter the username for the server.
Password (required): Enter the password for this account. Multiple layers of protection are in place, including AES 256 encryption, to keep your connection’s password safe. When editing this form later, you must enter this value again; it is stored only when the connection is saved and never displayed as text.
Header name (required): Provide the header name where the generated hash token will be added in the request headers. By default, the name is X-WSSE.
D. Edit common HTTP settings
  • Application details (contains the required settings Base URI and Media type)
  • Nonstandard API rate limiter
  • How to test this connection?
  • Advanced
E. Save, test, and authorize
