Set up a connection to Concur Invoice
SAP Concur Invoice is an invoice management solution that helps businesses automate accounts payable processes, including invoice capture, approval workflows, payment processing, and spend tracking.
Celigo integrator.io supports the Concur Invoice connection only from the US2, and EU2 geolocations.
Setting
Instructions
Name your connection *
Region *
Your Concur Invoice account region gets auto-populated once you successfully configure this connection.
Edition *
Your Concur Invoice account edition gets auto-populated once you successfully configure this connection.
OAuth 2.0 *
The OAuth 2.0 authentication method requires that the connection be configured through the SAP Concur App Center. Click Continue in the SAP Concur App Center, then follow the instructions provided in the Installation in the SAP Concur App Center article to complete the setup.
This connector documentation describes only the settings shown for the Simple view. For the corresponding HTTP settings, see OAuth 2.0 auth universal connector documentation.
