SAP Concur Expense is a cloud-based expense management solution that automates the creation, submission, approval, reimbursement, and auditing of employee business expenses. It is part of the SAP Concur travel and expense management suite.
Celigo integrator.io supports the Concur Expense connection only from the US2, and EU2 geolocations.
Region * |
Your Concur Expense account region gets auto-populated once you successfully configure this connection. |
Edition * |
Your Concur Expense account edition gets auto-populated once you successfully configure this connection. |
OAuth 2.0 * |
The OAuth 2.0 authentication method requires that the connection be configured through the SAP Concur App Center. Click Continue in the SAP Concur App Center, then follow the instructions provided in the Installation in the SAP Concur App Center article to complete the setup. |
For seamless file transfers, SAP Concur recommends replacing the expiring PGP key with a new PGP key as early as possible. For more information, contact the SAP Concur support team.
