Use {{join}} to concatenate multiple fields or literal strings with a chosen delimiter between each item. You can supply any number of items to join.
{{join delimiterField field1 field2 ...}}
delimiterField: The delimiter to place between each value (e.g.,
field1, field2, ...: One or more values or references to join.
Joining literal strings
{{join "-" "unicorn" "ponies"}}Produces
"unicorn-ponies". -
Combining record fields with a comma
{{join "," record.band1 record.band2 record.band3}}If
record.band1is"Iron Maiden",record.band2is"DIO", andrecord.band3is"(old)Metallica", the result is"Iron Maiden,DIO,(old)Metallica". -
Using a different delimiter
{{join "/" record.folder record.subfolder record.filename}}For
record.folder = "root",record.subfolder = "images", andrecord.filename = "logo.png", you get"root/images/logo.png".
You can pass in as many items as needed after specifying the delimiter.
If any of the items are arrays, each element will be joined using the specified delimiter.
Make sure your fields resolve to strings or can be converted to strings; otherwise, you may see unexpected results.
