regexSearch helper
The regexSearch helper returns the zero-based index of the first substring that matches a regular expression pattern within a string. If no match is found, it returns -1. Use it to locate the position of a pattern before extracting or replacing it.
Syntax
{{regexSearch field regex options}}
field -- The string or field to search. Required.
regex -- The regular expression pattern to locate. Required.
options -- Regex flags to apply. Optional. Common values: "i" (case-insensitive), "m" (multiline).
Examples
Find the position of a character
{{regexSearch record.total "5"}}
Input: record.total is "$1499.95"
Output: 7
The first "5" appears at index 7 (zero-based).
Find the position of the decimal point
{{regexSearch record.total "\."}}
Output: 5
The "." appears at index 5. The backslash escapes the dot so it matches a literal period rather than any character.
{{regexSearch record.comment "celigo" "i"}}
Input: record.comment is "HELLO Celigo"
Output: 6
The "i" flag matches regardless of case. "Celigo" starts at index 6.
Usage notes
  • The return value is zero-based: the first character is at index 0.
  • Returns -1 when the pattern is not found. Handle this in downstream mappings to avoid unexpected behavior.
  • Triple braces are not needed -- the helper returns a plain number that is not subject to Celigo's automatic string formatting.
  • For more on regex syntax and supported patterns, see Regular expressions (regex).
