occurrences helper
The occurrences helper returns the number of times a given substring appears within an input string. It’s useful for counting keyword matches, delimiters, or repeated text patterns.
Usage
{{occurrences str substring}}
  • str (required): The input string to search
  • substring (required): The substring to count occurrences of
Examples
Count how many times a word appears
{{occurrences record.text "foo"}}
Input:
  "record": {
    "text": "foo bar foo bar baz"
Output:
2
Count delimiter occurrences
{{occurrences record.path "/"}}
Input:
  "record": {
    "path": "/api/v1/resource/item"
Output:
4
Count character appearances
{{occurrences record.name "a"}}
Input:
  "record": {
    "name": "Banana"
Output:
3
  • Matching is case-sensitive by default ("Foo" ≠ "foo").
  • Overlapping matches aren’t counted separately.
  • Use it to validate input patterns or measure frequency of specific tokens in text fields.
